Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Nov 16, 2016 at 3:43 PM
    #7441
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Yeah I kind of remember that there was not a whole lot on 60 E of Parsons in 72,73.....That place has exploded over the years....
    Cuffs[QUOTED] likes this.
  2. Nov 16, 2016 at 5:11 PM
    #7442
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Grew up near Valrico & Sydney
  3. Nov 16, 2016 at 5:13 PM
    #7443
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Any of you go to school on that area? Brandon, Armwood, Bloomingdale?
    I did not but know many at each.
  4. Nov 16, 2016 at 5:52 PM
    #7444
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Haha, I ran the phone cables into Bloomingdale when it was being built. :D
  5. Nov 17, 2016 at 5:12 AM
    #7445
    IPNPULZ
    going to be fun!
    I went to Yates,Williams,Franklin,Mclane and BHS
  6. Nov 17, 2016 at 6:41 AM
    #7446
    Cuffs
    BHS. What class? They always had the best wrestling team in the state.
  7. Nov 17, 2016 at 7:03 AM
    #7447
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Doooorant! lol
    allenfab likes this.
  8. Nov 17, 2016 at 7:31 AM
    #7448
    Cuffs
    I know when that school was built. You're just a pup!
  9. Nov 17, 2016 at 7:56 AM
    #7449
    IPNPULZ
    going to be fun!
    would have been 83 but we moved and I went on to King... Yeah they had an impressive 30 plus year winning record funny thing is that they had kids from Plant city district coming to Brandon to wrestle but that was never proven of course...
    I think some School form South Fl stopped the winning streak in 2005 or so....
  10. Nov 17, 2016 at 8:35 AM
    #7450
    IPNPULZ
    going to be fun!
    Durant? that School was built in like 96 or 97?
    Cuffs likes this.
  11. Nov 17, 2016 at 8:48 AM
    #7451
    Cuffs
    One of my (still) best friends went to King but I can't recall what class. Would be close to 83, Dawna Mohr. And Sandy Forsythe would have been 83 or so at Brandon. My other friends at BHS were 85-86.
  12. Nov 17, 2016 at 9:03 AM
    #7452
    IPNPULZ
    going to be fun!
    It really is a small world...
    I have really lost touch with so many people, I do see some every once in awhile when back home. But as I do now I kept/keep a very low profile in HS with a very very small circle of true friends.
  13. Nov 17, 2016 at 11:59 AM
    #7453
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Anyone in here an electrician or have any friends who are? Dryer crapped out on me, had GE come out but it is either the plug, wiring to the plug or circuit breaker itself
  14. Nov 18, 2016 at 2:20 AM
    #7454
    Taco No Baka
    Lee
    Tampa, FL
    Well, damn, you just can't catch a break, yeah? Unfortunately, (knock on wood) that's one thing we haven't really had a need for. If it was A/C or plumbing, I'd recommend Integrity Air for the A/C and Drain Doctors for the plumbing. Can't help with the Electrician though.
    That said, replacing the outlet isn't that hard. It's pretty much the same as any other outlet. Replacing the cord on the drier is pretty simple as well. And honestly, the circuit breaker is usually pretty easy to replace as well. Only reason you'd really need an electrician would be if the wiring was bad.
    Rattletrap66[QUOTED] likes this.
  15. Nov 18, 2016 at 5:25 AM
    #7455
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    10-4 I'll give the outlet at try first and if not then the circuit breaker :fingerscrossed:
  16. Nov 18, 2016 at 5:44 AM
    #7456
    Taco No Baka
    Lee
    Tampa, FL
    Circuit breakers are super easy once you know how. It probably takes longer to take the cover off the panel and put it back on than it does to replace the actual circuit breaker. Found this video for ya so you can see how it works. :thumbsup:
    https://www.youtube.com/watch?v=jKAPpxK5T2E
  17. Nov 18, 2016 at 5:50 AM
    #7457
    Taco No Baka
    Lee
    Tampa, FL
    Oh, and when you change the outlet, be sure to smoke those connections down as tight as you can. If they aren't tight enough, the wires will get hot and burn the insulation off them and then you're screwed. BTW, IMHO, changing the outlet is harder than changing the C/B. :D
  18. Nov 18, 2016 at 7:37 AM
    #7458
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Thanks Lee!
  19. Nov 24, 2016 at 8:57 PM
    #7459
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Forgot to post but on Sunday I got it fixed, changed the circuit breaker, no luck. Changed the outlet and it worked!
  20. Nov 25, 2016 at 10:18 AM
    #7460
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    What's up everyone. So I just ordered some new shocks on all 4 corners, a leaf pack, uca's, bump stops etc...basically a complete suspension upgrade. Was wondering if there was anyone that could possibly assist me with the install. Would also be looking for a place to host this mod day as I live on base and don't really have anywhere to work on the truck. I'm an aircraft hydraulic mechanic so I'm somewhat mechanically inclined but would love to have someone with experience installing these components to assist/teach me some things. I literally just put the order in so it wont be here for a while. Just seeing if anyone would be down to help out.Thanks!
    mosquitoTaco likes this.
