Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Nov 30, 2016 at 6:47 PM
    #7541
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
  2. Nov 30, 2016 at 7:09 PM
    #7542
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
  3. Nov 30, 2016 at 7:21 PM
    #7543
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Don't know really, we just wanted to mess with him. One person did it & then another until it snowballed into that. Haha
  4. Nov 30, 2016 at 8:31 PM
    #7544
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Your name says Mike still
  5. Nov 30, 2016 at 8:32 PM
    #7545
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Perfect gif :rofl:
    SpruceTaco[QUOTED] likes this.
  6. Dec 1, 2016 at 2:06 AM
    #7546
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Yeah, I got the hint. Still thought it was Nammer until I read your post. ;)
  7. Dec 1, 2016 at 2:07 AM
    #7547
    Taco No Baka
    Lee
    Tampa, FL
    Green tacos gotta stick together, yo. :cool:
  8. Dec 1, 2016 at 4:43 AM
    #7548
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I changed it back after he saw what we did. Haha
  9. Dec 1, 2016 at 5:26 AM
    #7549
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
  10. Dec 1, 2016 at 5:30 AM
    #7550
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    :wave:
  11. Dec 1, 2016 at 5:56 AM
    #7551
    Soul Surfer
    Jimi
    Morning Mike!
  12. Dec 1, 2016 at 6:13 AM
    #7552
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Morning Jim!
  13. Dec 1, 2016 at 6:31 AM
    #7553
    Soul Surfer
    Jimi
    Mike do you know the best and cleanest way to run power to a accessory in Dash light switch so the lindicator portion of the light lights up when turning on the trucks headlight switch. And if so what electrical parts do I need to pick up sir? I'm weak in the wiring department . Any help would be appreciated. Thanks. :anonymous:
  14. Dec 1, 2016 at 7:58 AM
    #7554
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    When I did my switches I tapped into the wires for lighting on the factory switch next to it. I think it's a green wire for the positive. I unplugged the factory switch & with the dash lights on tested each wire on the plug with a test light. Hope that makes sense.
    I used one of these for the connection.
    Soul Surfer[QUOTED] likes this.
  15. Dec 1, 2016 at 8:04 AM
    #7555
    Soul Surfer
    Jimi
    Understood. Thanks Mike! Appreciate the help Hoss!!!
  16. Dec 1, 2016 at 8:08 AM
    #7556
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Your welcome!
  17. Dec 1, 2016 at 9:50 AM
    #7557
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
  18. Dec 1, 2016 at 10:30 AM
    #7558
    SilverJack
    SilverJack no one
    When tapping factory wires, I like to use minimally invasive taps like https://www.amazon.com/dp/B00H242NN...TF8&colid=2G43RLJZCQ3PU&coliid=I14I8KR9U8WNPX
    Vampire taps are ok, but I've had some of them cut the strands or break the whole wire. Better to use a less disruptive tap.
  19. Dec 1, 2016 at 2:52 PM
    #7559
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    So I attempted to bolt my sliders on today after work and when I went to remove one of the bolts that was required to be removed for the install I sheared the head right off of the bolt. Now it's just stuck in there :facepalm:. That put a stop to my plans pretty quick lol.
  20. Dec 2, 2016 at 6:49 AM
    #7560
    Timbo's Customs
    Timothy
    Lakeland FL
    That sucks try a easy out
    Strictlytoyz[QUOTED] likes this.
