Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Dec 2, 2016 at 6:55 AM
    #7561
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Yeah I have a set of ez outs that ill try after work today. It was getting too dark to try last night:fingerscrossed:
  2. Dec 2, 2016 at 7:11 AM
    #7562
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Maybe also spray down the other bolts with PB Blaster.
    Strictlytoyz[QUOTED] likes this.
  3. Dec 2, 2016 at 7:14 AM
    #7563
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Will do. Thanks for the tip
  4. Dec 2, 2016 at 7:15 AM
    #7564
    Soul Surfer
    Jimi
    Welcome, especially the threads if you have access to them!
  5. Dec 2, 2016 at 12:59 PM
    #7565
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Screw the PB blaster. Hit them with a 50/50 mix of acetone and ATF. Works a lot better. :cool:
    i30nes and Strictlytoyz[QUOTED] like this.
  6. Dec 2, 2016 at 1:07 PM
    #7566
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Things just aren't working out for me. My ez out broke off inside my broken bolt:frusty:.
  7. Dec 2, 2016 at 1:12 PM
    #7567
    Soul Surfer
    Jimi
    10-4!
  8. Dec 2, 2016 at 1:13 PM
    #7568
    Taco No Baka
    Lee
    Tampa, FL
    Well shit. If you can get the broken piece of easy out...um...out, you can bring it by. I have a good set of easy-outs that might work better. If not, yer kinda screwed. :eek:
    If you do want to bring it by though, let me know.
  9. Dec 2, 2016 at 1:30 PM
    #7569
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    If it's in a place where nothing will catch fire heat from a torch is your friend also.
  10. Dec 2, 2016 at 1:46 PM
    #7570
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Well I have an appointment tomorrow at toyota for some new leafsprings from the recall. Ill see if they can get the bolts out while they're at it. By the way its the 2 bolts (1 on driver 1 on passenger) that connect the cross member (that hold the carrier bearing) to the frame.
    Soul Surfer likes this.
  11. Dec 2, 2016 at 2:00 PM
    #7571
    i30nes
    i30nes Well-Known Member
    Tampa, FL
    21 MGM Sport
    Definitely made it easy to pop the suspension bolts. :thumbsup:
  12. Dec 3, 2016 at 7:31 AM
    #7572
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Dam you Toyota of Tampa Bay! So they called me last night saying my leaf springs arrived per the recall so I set up an appointment for this morning. I show up and they tell me they don't have any leaf springs and that they're gonna have to order them :facepalm:. So I ask if they can fix my stuck bolt issue and the guy says yeah they can take care of it. 10 minutes later he comes back and says they can't do it cause they don't have any of those bolts in stock and that he went ahead and ordered those too :frusty:. I told him I have replacement bolts and nuts in my truck to replace them and he said they cant use the bolts that I have :annoyed:. So now.........I wait......,,
  13. Dec 3, 2016 at 12:54 PM
    #7573
    i30nes
    Tampa, FL
    21 MGM Sport
    Never liked that dealership personally. They tried to tell me I had to pay for a loaner while they did warranty work. Didn't have to when I had other warranty work done, sure as hell wasn't going to now.
    Strictlytoyz likes this.
  14. Dec 3, 2016 at 1:11 PM
    #7574
    SilverJack
    SilverJack no one
    Is that the place on Fletcher? I avoid ToTB like the plague. Service takes forever and they try to add shit to my bill. Drive up to Wesley Chapel Toyo, they are a bit better.
  15. Dec 3, 2016 at 1:15 PM
    #7575
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Yep it's the one on Fletcher...Ill check them out. Thanks
  16. Dec 3, 2016 at 1:21 PM
    #7576
    SilverJack
    SilverJack no one
    I think Scooter still works there. Drop him an IM at Scooter WCT before you go and he will introduce you to the service managers.
  17. Dec 3, 2016 at 1:56 PM
    #7577
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    toyota tampa bay sold us a corolla with 6 miles on it and a repainted bumper
  18. Dec 3, 2016 at 2:41 PM
    #7578
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Revisiting Bradenton for a few days.
  19. Dec 3, 2016 at 2:58 PM
    #7579
    Soul Surfer
    Jimi
    Nice sunset. I'm just up the Coast! Enjoy your Vist! :)
    Cuffs[QUOTED] likes this.
  20. Dec 3, 2016 at 4:12 PM
    #7580
    Cuffs
    It's been fantastic! (Lived in the TB area for nearly 20 years)
    Hangin at Motorworks Brewing tonight watching football. It's going REAL good today!
