Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Jul 29, 2017 at 10:41 AM
    #8061
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Only thing I can add is that mud will wear out and break down a synthetic cable long before a steel cable. But that's honestly about the only advantage of steel over synthetic that I've heard, but it's something to considered with wheeling in Florida.
  2. Jul 29, 2017 at 12:38 PM
    #8062
    Hugopreston
    Hugopreston Well-Known Member
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Ok cool. How about power? 10klbs? 12klbs?
  3. Jul 29, 2017 at 12:56 PM
    #8063
    allenfab
    Todd
    Lakeland, FL
    General rule is to get one that is rated at 1.5x the weight of your truck. I'd do 10k at least
  4. Jul 29, 2017 at 3:00 PM
    #8064
    Team Flatline
    Team Flatline Not squatin' w/ my spurs on...
    Eric
    Up a creek, Fla
    PreRunner
    Maxtrac'd, Icons, Dakars...........
    Hugo, I just installed a Smittybilt XRC9500 with the synthetic line. The weight savings over the steel cable is roughly 50 lbs. And as for the $$, it was $387 shipped via DiscountBandit.com
    Hugopreston likes this.
  5. Aug 1, 2017 at 5:40 AM
    #8065
    SilverJack
    SilverJack no one
    Hey folks, can anyone recommend a good paint shop in the Tampa area? I want to get my hood done (right this time), and I have no intention of taking it to my old shop. I'm looking for a professional place not the usual half junkyard that most bodyshops tend to be. Any suggestions? Thanks!
  6. Aug 1, 2017 at 5:46 AM
    #8066
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Can't say I'd recommend the place that painted the OGT. They did an amazing job of smoothing out the body from where the clear coat was peeling off and all, but they did a crap job prepping it for the new paint. I have a bunch of places where the green has come off with glossy black paint underneath it. :mad:
  7. Aug 1, 2017 at 5:58 AM
    #8067
    SilverJack
    SilverJack no one
    Yeah, I'm kinda in the same boat. The body work was flawless, but the paint looks blotchy. I know silver is tough to match, but this looks like the flakes are not uniform. You can clearly see cloud patterns in the hood. I took it back, they wet sanded, didn't fix the issue and added a bunch of scratches. Like, you, I know which shop to stay away from, so now I need a dependable one.
    Hey, maybe we should start listing the bad shops, and maybe find a good one by elimination.
  8. Aug 1, 2017 at 6:24 AM
    #8068
    Taco No Baka
    Lee
    Tampa, FL
    If you're not a cheap bastard like me, you might try Carrollwood Collision Center on Gunn Hwy. They are ridiculously proud of themselves, but I heard they do great work. They wanted more than $4k to paint the OGT, just to give you a frame of reference.
  9. Aug 1, 2017 at 7:18 AM
    #8069
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    @Hugopreston
    TacoTRD78 likes this.
  10. Aug 1, 2017 at 9:02 AM
    #8070
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Give Kulas collision and customs a call. We do a lot of high end frame off restoration work but we frequent the everyday sideswipe. It won't be the cheapest paint job but it'll be damn worth it. Lol. If you're looking to have the hood painted, you should get the fenders and even the bumper if you want to be extra careful, blended.
  11. Aug 1, 2017 at 9:35 AM
    #8071
    SilverJack
    SilverJack no one
    Thanks for the suggestion, I'll have to give the shop a call. My 2014 is the stock Silver Sky and has been garage parked all it's life. The job should be an easy task of popping the hood off and painting it with factory paint. Bumper is gunmetal grey stoneguard, so no worries about blending. I just want someone who can lay metallic flake without screwing it up. I'm not sure what happened with the last job, but a good respray should fix it.
    Any ideas on what a hood paint would cost?
  12. Aug 1, 2017 at 9:45 AM
    #8072
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Gotcha. Not sure. I'm just a bodyman so I don't deal with quotes. Give him a call and let him know what you want.
  13. Aug 1, 2017 at 9:56 AM
    #8073
    SilverJack
    SilverJack no one
    Do you guys do vinyl wrap too? One option was to wrap or paint the center hood section to match the front end. It would cover the bad paint and give the truck a custom look. I had another shop quote vinyl and it was around $300. At that price, I'm wondering if paint would be a better idea.
  14. Aug 1, 2017 at 12:10 PM
    #8074
    NastyBogging
    NastyBogging Well-Known Member
    Justin
    2013 MGM DCSB Tacoma Sport.
    Do anyone know any decent trails in the sarasota to fort myers region?
  15. Aug 1, 2017 at 12:20 PM
    #8075
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Lazy Springs
    9591 Florida 82, Felda, FL 33930
    NastyBogging[QUOTED] likes this.
  16. Aug 8, 2017 at 5:39 AM
    #8076
    SilverJack
    SilverJack no one
    Called Friday, spoke to Brad, too busy that day for an estimate. Called yesterday, but no return call. I'm not going to beg someone to take my money.
    Anyone else know a shop in Tampa? Thanks gents.
  17. Aug 8, 2017 at 7:02 AM
    #8077
    lelizabeth88
    lelizabeth88 Member
    Lauren
    St. Petersburg, Florida
    2017 Super White Tacoma SR5
    Hey Everyone!!
    I just purchased my first Tacoma - 2017 White SR5. Looking to install some upgrades on my truck.
    I posted a new thread in the "New Members" area - but JD was nice enough to recommend this Tampa Bay thread, since I live in St. Pete. Thanks again JD!! :cheers:
    I wanted to see if anyone has any recommendations for the following items:
    1. Running boards/ nerf bars
    2. Tonneau covers
    3. Tire package
    4. Grill options
    **Anything you might recommend for a newbie?!?!
    Thank you so much!
    - Lauren
  18. Aug 8, 2017 at 7:04 AM
    #8078
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    :hattip: Again Welcome Aboard Lauren!
    lelizabeth88 likes this.
  19. Aug 8, 2017 at 7:13 AM
    #8079
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Welcome! I wish I could help with the first three but for grille options, could go with a mesh style grille
    https://www.tacomaworld.com/threads...sh-bezels-updated-with-new-iphone-app.394542/
  20. Aug 8, 2017 at 7:14 AM
    #8080
    Taco No Baka
    Lee
    Tampa, FL
    Carrollwood Collision Center. :thumbsup:
    :wave: Welcome to the asylum for the Tacoma-poor...it's like house poor but you end up spending all your $$$ on your Tacoma instead of your house, haha.
    If you have a double cab short wheel base, there's a member on the Classifieds that is looking to sell his tonneau cover. Might be able to get a deal on it. It's a 2nd Gen though so I dunno if it'd work on a 3rd Gen.
    https://www.tacomaworld.com/threads/the-florida-classifieds.171520/page-771#post-15772415
    If you're 4wd or you intend to come to our trail rides (we have quite a few 2wds that come out to run trails), I'd recommend getting a set of rock sliders to protect your rockers rather than step bars. If you don't intend to come to the off-road meets, then the N-fab Step bars are pretty popular.
    That's all I got. :D
