Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Feb 27, 2019 at 2:31 PM
    #8601
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    I was born, raised and currently living in the 727.
  2. Feb 27, 2019 at 3:20 PM
    #8602
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    We could have a mod day. Plenty of able people
    Ulfr likes this.
  3. Feb 27, 2019 at 6:40 PM
    #8603
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    My carport is available. I need to swap out my rear third anyway, so I can get all that stuff sent up to ECGS. The poor OGT is about buried under leaves and bird shit. Her fault though. She's the one that decided to have an electronics problem that I can't diagnose.
    Rattletrap66[QUOTED] likes this.
  4. Feb 28, 2019 at 2:09 AM
    #8604
    Suggestausername
    Suggestausername Nerd
    J
    Tampa
    I’m thinking about getting a Jacktech spring compressor and doing it myself.
  5. Feb 28, 2019 at 2:14 AM
    #8605
    Taco No Baka
    Lee
    Tampa, FL
    You can also do it by jacking up your LCA, removing the nut from the top of the shock and then letting the LCA down. Installation is the reverse.
  6. Feb 28, 2019 at 3:56 AM
    #8606
    Suggestausername
    J
    Tampa
    I’ve seen that. I guess as long as the lca doesn’t slip off the jack post, it could be okay.
  7. Feb 28, 2019 at 4:27 AM
    #8607
    Taco No Baka
    Lee
    Tampa, FL
    Since you have to take the spindle loose from the LCA anyway, it shouldn't be an issue with a floor jack...a bottle jack might be a little sketchy but it should be pretty solid with a floor jack under the ball joint stud. If you don't have a floor jack...
    The offer stands. My driveway is free, and I need to swap my rear third and I think I have a leaking wheel cylinder, so I'll probably replace them both while I have the lines disconnected, so we could have some folks get together for a mod day. Many hands make light work. :thumbsup:
  8. Feb 28, 2019 at 3:28 PM
    #8608
    Suggestausername
    J
    Tampa
    Lee, that is awesome! I'll keep the thread posted as to my progress.
    No stranger to tech days. Swapped various NC Miata suspension bits at least twice, did a clutch on an NA Miata on the garage floor, numerous brake jobs, lifted a Subaru Forester (of all things) with a buddy in my own carport. Even tackled a home-brew alignment with some help. When we had that one realigned professionally it was still within spec, but not as precise as the alignment rack.
    Most of the stuff I've done has been suspension, most of it has been at stock height or lower, so it goes back together easily. The lift was an eye opener, trying to coax a taller strut assembly in was a challenge, but we did it! The 5100s for my truck will be on the .85" setting, so I'm hoping it's fairly simple and doesn't require too much flexing to get them back in place.
    I've got a line on a Jacktech SK-3000 compressor, so I'm going to attempt it at home with spare labor provided by my homeboy.
    Edit: I'm wondering if my little 1.5 ton aluminum HF jack will go high enough to get the truck off the wheels. It's been completely adequate for the Miata and the wife's sedan. Going to have to check that out real soon.
  9. Feb 28, 2019 at 3:49 PM
    #8609
    Taco No Baka
    Lee
    Tampa, FL
    The trick to getting the taller coilover in there is to realize you will have to get it aligned anyhow and just suck it up and loosen the LCA alignment cam bolts so you can rotate the LCA down. Once you do that it's a piece of cake. Just don't tighten them back up until everything is together and it's sitting at ride height.
    As far as jack height...a block of wood or two and you're good to go. But, yes, I have the HF floor jack that has the extra high lift and is extra heavy to pick up :p. I still usually use a block of wood though, just to minimize the metal to metal contact.
  10. Feb 28, 2019 at 3:55 PM
    #8610
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    The HF low profile jack reached on my 2nd gen with a 3" lift, but the regular hf jack doesn't.
    I had pushed my LCAs down with a pry bar when I did my lift. My coils were already in the shock though.
  11. Feb 28, 2019 at 4:09 PM
    #8611
    Suggestausername
    J
    Tampa
    We had to pry down on the LCAs in the forester (well, stand on the knuckle and grunt) to get the assembled strut in. It was a challenge, but it got done.
    My plan is to follow (roughly) the instructions in ToMoCo's workshop manual: remove the skid plate, remove the sway bar and separate the tie rod end ball joints from the knuckle and go from there- pull out the assembled strut and disassemble it on the fancy spring compressor. If it won't come correct on reassembly, the LCA bolts come out.
    Taco No Baka[OP] likes this.
  12. Feb 28, 2019 at 4:23 PM
    #8612
    Taco No Baka
    Lee
    Tampa, FL
    IIRC, I just stepped on the ball joint mount when I did the lift on the OGT. The weight of my fat ass was enough to press it down enough. When I did the T4R, I loosened the cam bolts. It was a lot easier. In both cases I paid to have the coilovers pre-assembled. Now the rear coils on the T4R were a real PITA. The right side was slightly easier but in both cases, I had to use ratchet straps to compress the coils to get them in place. I knew the upper shock mount was going to be a beotch, but I thought the coils would be simple, just let the rear axle down, slip them in and then jack it up until I could get the shock on the lower mounts. I didn't get that lucky.
  13. Feb 28, 2019 at 4:30 PM
    #8613
    Taco No Baka
    Lee
    Tampa, FL
    You probably don't need to take the tie rod ends off the spindle. Once it's disconnected from the lower ball joint you could probably just rotate the spindle out of the way and put a bungee or a strap on it to keep it there. It worked for me, but then the 1st Gen Taco and 3rd Gen T4Rs have the steering rack behind the diff.
    Edit: well, thinking about it if you're 4WD you probably will have to remove the tie rod end. Should still work if you're a Prerunner though.
  14. Feb 28, 2019 at 4:32 PM
    #8614
    replica9000
    2019 T4R ORP
    I was hoping it would be easy for the rear coils. The front should be the same as the Taco. I think the passenger side LCA was always harder to push down. The rear shocks are the Taco were a pita. I had to cut them off. Hoping the v 4Runner is easier.
  15. Feb 28, 2019 at 4:40 PM
    #8615
    Taco No Baka
    Lee
    Tampa, FL
    Well, it was probably just my bad luck with the coils, and I'm a 3rd Gen, so your mileage may very. The shocks though, I had to crush the metal dust shields on the factory shocks with a C-clamp until they were pinched down on the piston shaft keeping it from spinning to get the top nuts off. The whole thing was a pain.
  16. Feb 28, 2019 at 4:46 PM
    #8616
    replica9000
    2019 T4R ORP
    I'll have to take a closer look when the weather warms up here. I want to do it soon before the liquid salt makes everything rusty. Eventually plan on moving down your way where it's warm and salt free
  17. Feb 28, 2019 at 5:48 PM
    #8617
    Taco No Baka
    Lee
    Tampa, FL
    Warm? You mean hotter than the hinges on the gates of hell for 9 months out of the year, haha. But I guess it is fairly salt-free as long as you don't drive in the salt water mud or back your boat/PWC trailer into the water up to your rear bumper.
  18. Feb 28, 2019 at 5:56 PM
    #8618
    replica9000
    2019 T4R ORP
    I like the heat. I'd much rather fry than freeze. I was in Clearwater last September and it was great. It was weird seeing people wearing hoodies while it was still 80° though.
  19. Feb 28, 2019 at 6:38 PM
    #8619
    Taco No Baka
    Lee
    Tampa, FL
    Wait until you see us bundled up like Eskimos when it hits 60*, lol. Or weirder yet, people like @Timbo's Customs who will be wearing a heavy winter coat below 50* ...and still be wearing shorts. :rofl:
    Honestly, I can't really say with much certainty since my doctor put me on a medication that made me a lot more heat tolerant, but it seemed like it was pretty mild last summer.
  20. Mar 1, 2019 at 11:46 AM
    #8620
    replica9000
    2019 T4R ORP
    We have guys like that up here. 10° outside still wearing shorts. I'm the opposite. I wear jeans all year round no matter how hot it gets.
