Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Mar 1, 2019 at 5:52 PM
    #8621
    Suggestausername
    Suggestausername Nerd
    J
    Tampa
    What's this medication? I need some of that in my life.
  2. Mar 1, 2019 at 10:40 PM
    #8622
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    :anonymous: :wink: :D
  3. Mar 8, 2019 at 9:00 AM
    #8623
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    I have some bilstein I need to install and I don’t own the tools to install them! If you guys where to do a mod day, what day?
    Trd sport tacoma likes this.
  4. Mar 8, 2019 at 9:23 AM
    #8624
    Taco No Baka
    Lee
    Tampa, FL
    Couldn't say at this point. The OGT is at the stealership right now, where I'm getting screwed. Every time I take the truck in for an idle issue, they always say it's the IABV and it never is, but I guess if I want them to fix the problem, I'm going to have to let them replace it so they can't use it as an excuse. It pisses me off, but I guess that's what I get for being ignorant of that computer controlled bullshit. Just from speaking to the tech yesterday while he put on a dog-and-pony show for me to demonstrate how the valve was not working (which was bullshit, but I wasn't confident enough to call them on it until I got home and played with the other IABV I had already changed out), I'm pretty sure I know what the problem is and it's one of the two things I thought might be wrong with it. I bet they are going to try to tell me it's the ECU next.
    :rant:
    Edit: It really sucks to know enough to know when I'm being screwed but not enough to figure out the problem on my own. :annoyed::frusty:
  5. Mar 8, 2019 at 9:53 AM
    #8625
    RedDeadTaco
    Andrew
    Aiken, SC
    Are you at Toyota of Tampa bay? They are smucks
  6. Mar 8, 2019 at 9:57 AM
    #8626
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    I dont think stadium Toyota is any better
  7. Mar 8, 2019 at 10:00 AM
    #8627
    RedDeadTaco
    Andrew
    Aiken, SC
    I like Toyota of Wesley Chapel. Went in to get a recall done and then the sales rep was trying to pressure me into changing out my diff fluids. Once I told him I’ll do it myself if anything, he shut up unlike Toy of TB
    Scooter WCT likes this.
  8. Mar 8, 2019 at 10:00 AM
    #8628
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, but almost the same thing happened at WCT. Only I paid them the diagnosis charge for them to tell me it was the IABV and when I went home and bought a new one and installed it, it didn't fix shit. TOTB took care of me before when I first got the truck. I took it there to get it inspected to see what problems I might be looking at and to get the timing belt changed since it was due, and other than being pricey IMHO, they didn't go overboard. Took it there this time because I had to ride my bike home, and it was the closest place to me.
  9. Mar 8, 2019 at 10:01 AM
    #8629
    RedDeadTaco
    Andrew
    Aiken, SC
    In conclusion, dealerships suck haha
  10. Mar 8, 2019 at 10:05 AM
    #8630
    Taco No Baka
    Lee
    Tampa, FL
    Pretty much any shop sucks. You roll the dice anywhere you take it. Only reason I take it to the stealership for crap I can't do on my own is because at least it'll get OEM parts and a warranty.
  11. Mar 8, 2019 at 11:34 AM
    #8631
    Taco No Baka
    Lee
    Tampa, FL
    Well, I got the truck back and they definitely stuck it in and broke it off, even though I did manage to get 10% off the bill. They also claimed that all they did was replace the IABV and did nothing else. The up shot is, the truck is now idling better than it has in 3 years or so, so whether I buy it that the IABV was the problem or not, the issue is fixed, even if it did cost me about 4x what it would have cost me to replace the valve myself in less than a half an hour. (I'm still not buying it that the valve was the problem since I swapped it out myself before I took the truck to them and what are the odds that two different valves had the exact same issue?)
    Soul Surfer and Trd sport tacoma like this.
  12. Mar 16, 2019 at 8:17 PM
    #8632
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Lee I finally did it. I joined the 1st gen club.
  13. Mar 16, 2019 at 8:26 PM
    #8633
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Wow. Bro bump
    Soul Surfer and allenfab like this.
  14. Mar 16, 2019 at 8:38 PM
    #8634
    Taco No Baka
    Lee
    Tampa, FL
    That's awesome! You're a little behind the times though. We're all going to 3rd Gen T4Rs. :rofl:
    At least Todd will be right there with ya as will I unless I find a deal like Timbo did on a 97-98 T4R, then Todd's gonna be the new owner of the OGT so he can put it on tons and 40s to keep up with Tim. I'll be the proud owner of the OG4, OD Green T4R with 35s, 4.88s, and way better brakeover and departure angles.
    Either way, I'll soon be joining the "I got a winch and you don't" crowd. Gotta Warn 10k Xeon in box sitting in my room.
    Soul Surfer likes this.
  15. Mar 16, 2019 at 8:39 PM
    #8635
    Taco No Baka
    Lee
    Tampa, FL
    Oh, and Pics or it didn't happen...
    :worthless:
  16. Mar 16, 2019 at 8:55 PM
    #8636
    xweslingx
    Wes
    Durham, NC
    I looked at 3rd gens for a while but I need a truck bed. Here’s a pic for ya. 1238C517-40E5-4F26-BA61-8B98ABC0CD43.jpg
  17. Mar 17, 2019 at 3:58 AM
    #8637
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    I’ve had good experience at Sun Toyota. Bought my truck at ToTB, took it to them for 5K service, and they were complete idiots. Went back to Sun for my 10K (where I’d had my T4R serviced) and they treated me right (in addition to having decent techs).
  18. Apr 1, 2019 at 7:34 PM
    #8638
    jedirye
    jedirye Wannabe
    Florida
    2013 Baja Supercharged
    ToTB bought out Sun Toyota a year ordo ago, granted still run by different managers, etc.
    I'm giving WCT a try tomorrow. Honestly, they actually already seemed very knowledgeable compared to ToTB regarding SCer, etc. We'll see, got some warranty work anyway so.... Fingers crossed
  19. Apr 2, 2019 at 6:24 AM
    #8639
    Taco No Baka
    Lee
    Tampa, FL
    Say hi to @Scooter WCT on the sales floor while you're there. :thumbsup:
  20. Apr 2, 2019 at 6:29 AM
    #8640
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    Unfortunately I'm off today, but I'm coming in around 12:30 to take care of some things. I would definitely Love to see this 2013 Baja w/ a SC :drool:
