Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Mar 30, 2015 at 11:35 AM
    #1601
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    It would cost me $160...Ridiculous. We could put your shocks on too.
  2. Mar 30, 2015 at 11:50 AM
    #1602
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    It'd maybe cost ya lunch and you'd need to barrow a set of spring compressors from your favorite autoparts store. It's not my favorite way to do it though. Those screw type spring compressors seem a little sketchy to me, but we have done it when we put the 5100s on Spruce's truck. Just adjusting them may or may not be easier than replacing the whole shock.
    Still though, it might be worth checking out how much someone would charge you to do it if you brought them the coilovers already off the truck. Getting them off is pretty easy. You just take off the brake caliper, tie-rod end, and then unbolt the LBJ from the spindle and then move the spindle out of the way (oh and you'll have to either remove the bolt from the stub end of the CV axle or pull the lock-out apart and remove the snap ring from the CV axle so you can get the axle out of the hub, depending on which type you have). After that it's just the three nuts on the top of the coilover and the one bolt on the bottom. Just make sure to mark the coilovers left and right. It might take some finagling to get them out and more to get them back in, but it's a pretty simple job. ;)
  3. Mar 30, 2015 at 11:52 AM
    #1603
    Taco No Baka
    Lee
    Tampa, FL
    Like I said, it might be quite a bit cheaper if you took the coilovers up to them off the truck already. ;)
  4. Mar 30, 2015 at 12:07 PM
    #1604
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I want to say when I called around it was like 50 bucks to switch my coils over to the 5100's. I just can't remember if it was $50 total or each. I rented the spring compressor with a $50 deposit & got it back when I returned it, so it cost nothing really. But there was definitely a high pucker factor.
  5. Mar 30, 2015 at 12:12 PM
    #1605
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, $50 total would definitely be worth not dealing with the pucker factor. $50 per C/O might make me have to think about it though. :D
    Too bad none of us has an arbor press. That'd probably make things easy. just squish it until it's compressed enough to move the clip and let it relax.
  6. Mar 30, 2015 at 12:13 PM
    #1606
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    A guy on cl, he's charging 250
  7. Mar 30, 2015 at 12:17 PM
    #1607
    Taco No Baka
    Lee
    Tampa, FL
    Is he including the 40 grit sand paper condom with that? :eek:
  8. Mar 30, 2015 at 12:23 PM
    #1608
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I think Nam is answering Michaelrussell's question about the bumper.
    Yes it would've been helpful if he had quoted Michael.
  9. Mar 30, 2015 at 12:24 PM
    #1609
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Danggit Nam
  10. Mar 30, 2015 at 12:24 PM
    #1610
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :rofl:
  11. Mar 30, 2015 at 12:26 PM
    #1611
    nammer
    Nam
    Bradenton, Florida
    On phone, mikes was the last post I saw then y'all blew it up
  12. Mar 30, 2015 at 12:28 PM
    #1612
    Taco No Baka
    Lee
    Tampa, FL
    :boom::boom::boom:
  13. Mar 30, 2015 at 12:28 PM
    #1613
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    lol Mike's post was at 11:40 and the next post wasn't until 2:30 (1stgen)
  14. Mar 30, 2015 at 12:45 PM
    #1614
    1stgen
    18 SR5
    I did that when I set them at .75 the first time.
  15. Mar 31, 2015 at 11:36 AM
    #1615
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    Where do you guys suggest in terms of a trusted place for an alignment? Somewhere that has experience with offroad vehicles that won't be completely dumbfounded by a lifted truck with aftermarket UCA's. I'm in Temple Terrace so north Hillsborough is preferred, but anywhere local would work.
    There's a place on 301 between I4 and Sligh called Toy House that has a nice FJ40 out front. I don't believe it's a dedicated offroad shop though. Anyone have any experience with them?
  16. Mar 31, 2015 at 3:00 PM
    #1616
    1stgen
    18 SR5
    rattletrap, You ready to take me fly fishing if I bring my kayak home and I get a fly rod?
  17. Mar 31, 2015 at 4:16 PM
    #1617
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2023 TACOMA LIMITED DCLB LIFTED
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 5% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, LOCK WHEELS 17 X 9 -12 W 275/70R17 TOYO OPEN COUNTRY TIRES
    I always used tires plus on the corner of 60 and gulf to bay. Never any issues with any of my trucks and always got the lifetime alignment.
  18. Mar 31, 2015 at 5:33 PM
    #1618
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Yea man I'm down! Just let me know
  19. Mar 31, 2015 at 5:46 PM
    #1619
    1stgen
    18 SR5
    I get my paycheck tomorrow so ill have to see.
  20. Mar 31, 2015 at 9:08 PM
    #1620
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Sounds good :D
