Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Apr 14, 2015 at 12:39 PM
    #1661
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    i wouldn't be able to make it this weekend either
  2. Apr 14, 2015 at 3:11 PM
    #1662
    taco8603
    taco8603 Well-Known Member
    Philip
    Kenneth city Florida
    2019 White Tacoma DCSB SR 4x4
    lt265/75/16
    Let's do a Sunday lunch at Texas Roadhouse in baypines next to walmart
  3. Apr 14, 2015 at 5:42 PM
    #1663
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    Too far for me.
  4. Apr 15, 2015 at 7:10 AM
    #1664
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Going to do some trail riding at Citrus WMA tomorrow @10 AM. If anyone wants to join let me know
  5. Apr 15, 2015 at 8:02 AM
    #1665
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    By yourself?
    Wow, you really got the Citrus bug. :D Maybe we'll have to set up a Hardrock trip for you to see how you like that. ;)
  6. Apr 15, 2015 at 8:06 AM
    #1666
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    No lol with Scooter WCT and a few others. He doesn't ever get on here anymore. He's always on the Facebook one though. Oh and I would be down for Hardrock!
  7. Apr 15, 2015 at 8:16 AM
    #1667
    Taco No Baka
    Lee
    Tampa, FL
    Okay, cool. I wasn't going to let you go by yourself had that been the case.
    As far as Hardrock though, it might be a while before I can go. I think the Richloam trip might be the last wheeling trip for me before I pack it in for the summer. It's not fun for me if it's too hot. :eek: Guy might set up a summer visit though once he gets his new axle squared away, otherwise, I probably wouldn't be up for it until November or so. I'm definitely due though. The place is probably completely different from the last time I went, haha.
  8. Apr 15, 2015 at 12:05 PM
    #1668
    zkdawg
    zkdawg Greenville Taco
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Fog light mod, JBA LT headers, drop-in k&n filter, energy bushings, tried fold topper, 2nd air filter removed, all new stereo system minus subs, plastisol the wheels.
  9. Apr 15, 2015 at 12:49 PM
    #1669
    nammer
    Nam
    Bradenton, Florida
    what makes you think it's the cluster?
    did you have the codes read?
    how long have you had the truck?
    does it work intermittently, or never has?
    I know you said no fuses are blown, but did you check all the fuses, inside cab and in engine?
    anything else on the cluster not work?
  10. Apr 15, 2015 at 1:12 PM
    #1670
    nammer
    Nam
    Bradenton, Florida
  11. Apr 15, 2015 at 7:57 PM
    #1671
    zkdawg
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    1. I checked ohms though all wires in the airbag occupant detection system and found a solid pink wire to have 1.80 ohms where everything else had 0 and so I followed it to the cluster.
    The wire going in had 0 ohms and the wire coming out had the 1.80 ohms.
    2. Yes, I had code 32 which has to do with the occupant detection system.
    I replaced the 2 main components in the system with no change.
    3.I have had the truck for 3+ months and it has always had this problem.
    4.it comes and go but mostly comes. I went to school for automotive for 2 years and asked my teacher his opinion end he and I both think its a short in some component.
    5.I have not but from what is happening it doesn't seem/act to be a fuse.
    6.what I listed in my thread is the only things to go wrong
  12. Apr 15, 2015 at 9:08 PM
    #1672
    nammer
    Nam
    Bradenton, Florida
    ok cool, so you def know more about electronics than me, I don't even know how to use a multimeter
    I did want to clarify one thing, on question 4, when you say it comes and goes, so at times, the light is off, and everything works? or does the light comes and goes, and it all the other stuff doesn't ever work. If the the other stuff doesn't ever work, I would highly suggest all the fuses, if the those things come and go too, then i'd agree with you that it doesn't sound like a fuse, also
    i found code 32 to be speed sensor?
    http://www.customtacos.com/forum/128-2005/152746-abs-light-always.html
  13. Apr 16, 2015 at 4:35 AM
    #1673
    zkdawg
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    The light is on 95% of the time and my truck works properly 5% of the time.
    Sorry, code 32 abs codes
  14. Apr 16, 2015 at 8:47 PM
    #1674
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    yea man! Gonna put it all together hopefully this weekend. Maybe I'll upload a teaser real quick. Here's a baby flex pic
  15. Apr 16, 2015 at 9:12 PM
    #1675
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  16. Apr 17, 2015 at 3:14 AM
    #1676
    Taco No Baka
    Lee
    Tampa, FL
  17. Apr 17, 2015 at 3:47 AM
    #1677
    Hugopreston
    Hugopreston Well-Known Member
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    So my bday is tomorrow and I got myself a birthday present. Lol. Should be her within the month. Can't wait for it. It's going to change the truck even more.
  18. Apr 17, 2015 at 4:25 AM
    #1678
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I'm pretty sure the Croom your thinking of is restricted to atv's & bikes buuuut right next to the bike park it the Croom WMA & my guess is that's where the trail rides are taking place. I've hunted there a few times years ago & remember it being kinda hilly & sugar sand, don't remember any of those areas but then again didn't go all over the place either.
    Another video I found while watching yours.
    https://youtu.be/5kco59juI2Q
    You can download the map at the top of the page.
    http://m.myfwc.com/hunting/wma-brochures/sw/croom/
  19. Apr 17, 2015 at 5:04 AM
    #1679
    nammer
    Nam
    Bradenton, Florida
    happy bday, hmmm, any hints :spy:
  20. Apr 17, 2015 at 5:12 AM
    #1680
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    I'd be in! Always down for a trail ride
