Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Apr 24, 2015 at 6:56 PM
    #1721
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I researched it a little. Still didn't make sense why I was seeing a map, but it says it will show a map if you save it for offline use where you may not have a data signal. It also said that it uses both GPS and the cell towers to pin point your location. It'll do it with just GPS, but it's faster if it can use the cell towers too.
    BTW, just installed a new router Verizon sent me. What a crappy experience that was. I was about ready to throw the thing out into the street, drive over it with the Taco, then send them back the broken effin' pieces packed in dog shit as a "thank you" for how effin' helpful their automated answering machine was when the stupid thing wouldn't connect to the internet. :rant::rant::rant:
    I had unhooked it and hooked the old router back up, then tried the verizon phone number again once I cooled down and actually got it to work. So I hooked the new router back up and in the process of going though their troubleshooting menu, the thing decided to connect and start working. So while I'm still pissed off at that stupid answering machine, my internet connection should be about 10x faster. :eek:
    Speed test shows I'm banging 58.5 Mb/s down and 61.36 Mb/s up now.
  2. Apr 25, 2015 at 12:42 AM
    #1722
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    I'm rubbing somewhere when I make sharp turns, how exactly do i figure out where it's rubbing? These things make a nice whining noise on the road around 55 but I don't care :) I already got two compliments on it from people I don't know at 2am at the gas station.
  3. Apr 25, 2015 at 7:26 AM
    #1723
    Taco No Baka
    Lee
    Tampa, FL
    Basically you just look for the scuffed spot in the wheel well. The likely spots are the wheel well liner where it covers the pinch weld, the frame where the aft edge of the tire would hit it, the fender flare, and probably those mud flaps.
  4. Apr 25, 2015 at 7:35 AM
    #1724
    1stgen
    18 SR5
    can I trim the wheel well with some sand paper?
  5. Apr 25, 2015 at 7:53 AM
    #1725
    Taco No Baka
    Lee
    Tampa, FL
    the liner? You can trim it with a pair of scissors or a razor knife. Be careful that you don't cut yourself if you use a razor knife though. ;)
  6. Apr 25, 2015 at 7:56 AM
    #1726
    1stgen
    18 SR5
    okay I'll check it out
  7. Apr 25, 2015 at 7:57 AM
    #1727
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Try taking the mud flaps off first, that may be all you need to do.
  8. Apr 25, 2015 at 9:36 AM
    #1728
    Taco No Baka
    Lee
    Tampa, FL
    That could be, but if he's running 33s now, my money is on the wheel well liner where it goes over the pinch weld. Of course, once he trims that, he's probably going to have to flatten the pinch weld so the tires don't hit it when wheeling.
  9. Apr 25, 2015 at 9:46 AM
    #1729
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Very true, know he's a 1st gen but I had to trim the wheel well liner in front of the tire & the inside corner of the flare behind the tire. I still rub the cab mounts when the truck is full of peeps. I guess I just need to go higher. Haha
  10. Apr 25, 2015 at 12:03 PM
    #1730
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Haha Maybe not that much, I have another 3/4" available on my 5100's & would need 2" block. Dont know if that would be enough, Just want enough not to rub. That would put me at 7".
  11. Apr 25, 2015 at 1:57 PM
    #1731
    Taco No Baka
    Lee
    Tampa, FL
    Have you guys ever heard of putting Tundra front breaks on a Tacoma? Specifically, 1st Gens, but 2nd Gens too I guess. I heard about it for a 3rd Gen 'Runner, but I'm wondering it it would work for a Taco as well. Maybe the rears too. I know mine could use a little stouter braking.
  12. Apr 25, 2015 at 2:23 PM
    #1732
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    have you checked TTORA for any info? I know that forum is almost dead, but there is a lot of technical info over there
  13. Apr 25, 2015 at 2:52 PM
    #1733
    Taco No Baka
    Lee
    Tampa, FL
    Not as yet. Just wondering if anybody knew anybody that did it. That sort of thing. I guess I could really research it, but I'm afraid I'm going to find out I need to go up to 16" wheels to do it. :p
  14. Apr 25, 2015 at 5:43 PM
    #1734
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Sounds like ome 885's and lr uca's are in your future along with a 2" block.
  15. Apr 25, 2015 at 5:44 PM
    #1735
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Not the near future. Haha
  16. Apr 26, 2015 at 5:03 AM
    #1736
    Taco No Baka
    Lee
    Tampa, FL
    The new interface...Meh. Looks kinda washed out, but I guess we'll get used to it. :p
  17. Apr 26, 2015 at 7:05 AM
    #1737
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Yeah it's gonna take some getting use to.
  18. Apr 26, 2015 at 7:14 AM
    #1738
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Where the hell did my sig pic go?
  19. Apr 26, 2015 at 7:16 AM
    #1739
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    hmmm, mine's not there either :(
  20. Apr 26, 2015 at 8:05 AM
    #1740
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I can't figure out how to do it.
