Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. May 1, 2015 at 7:52 AM
    #1801
    SRQ Tacoma
    SRQ Tacoma Member
    Dalton
    Sarasota
    2013 MGM DCSB
    4 inch kit. W/blocks. Not sure how one checks back spacing! Can you Google it for me? J/K
  2. May 1, 2015 at 7:52 AM
    #1802
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Oh ok I'll send them anyway.
  3. May 1, 2015 at 7:57 AM
    #1803
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Haha, you have to take one off to measure it for the mounting surface to the lip.
  4. May 1, 2015 at 9:57 AM
    #1804
    SRQ Tacoma
    SRQ Tacoma Member
    Dalton
    Sarasota
    2013 MGM DCSB
    According to the wheel specs its offset is 15mm & has a width of 7" & a backspacing of 4.5"
  5. May 1, 2015 at 10:35 AM
    #1805
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    If the backspace is 4.5" then they will work.
  6. May 1, 2015 at 10:40 AM
    #1806
    SRQ Tacoma
    SRQ Tacoma Member
    Dalton
    Sarasota
    2013 MGM DCSB
    So would you recommend 1.25" wheel spacers just for the back?
  7. May 1, 2015 at 10:42 AM
    #1807
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    That's what I have, I think they look pretty even.
  8. May 1, 2015 at 10:46 AM
    #1808
    SRQ Tacoma
    SRQ Tacoma Member
    Dalton
    Sarasota
    2013 MGM DCSB
    drooooooooooooooooooooooooooool :rain:
    Text me Spruce, (941)-321-4754
  9. May 1, 2015 at 6:38 PM
    #1809
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Ya know, if you guys are going to do this at Mike's place, it might behove Dalton to see if he can make an evening appointment at Tires Plus or something to get an alignment afterwards. SRQ is quite a haul with a scragged alignment.
    Chances are I'm not going to be able to make this one. Next weekend is Mother's day (and I'm probably going to be busy patching up the OGT Saturday) and the following weekend is the Citrus trail clean-up, I think. After that, I might be have some spare time, depending on if something goes wonky with the OGT just riding around Citrus collecting trash. She's already not happy with me and I can't imagine she's going to be pleased impersonating a garbage truck. o_O
    Still, I've been using the downtime while waiting for the new axle seal to get here to address a bunch of little issues, so maybe she'll cut me some slack. :p
  10. May 1, 2015 at 6:46 PM
    #1810
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    We haven't set a date yet. I agree with ya, can't do anything next weekend being mothers day weekend.
  11. May 1, 2015 at 7:00 PM
    #1811
    Taco No Baka
    Lee
    Tampa, FL
    Understood. I was just saying I'm pretty much obligated for the next two weekends so unless he is willing to wait 3+ weeks for my schedule to clear, I probably won't be able to make it. Like I said though, I will probably have some time after the trail clean up if you guys want to factor that into the date selection.
  12. May 1, 2015 at 8:39 PM
    #1812
    SRQ Tacoma
    SRQ Tacoma Member
    Dalton
    Sarasota
    2013 MGM DCSB
    Well not sure what you guys have going on, but everything should be here this Thursday! I work from home so my schedule is flexible, I usually have wedding gigs on weekends too. Not sure if anyone is interested in a friday afternoon install, of course I have ants in my pants to get it on, but for quality, & cheap work I can wait (a little while).
  13. May 1, 2015 at 8:53 PM
    #1813
    Taco No Baka
    Lee
    Tampa, FL
    Hmm...I'm pretty flexible on weekdays too normally, but the rest of us tend to have the standard mon-fri gigs. This operation isn't one I'd recommend trying to tackle in an afternoon either. They are usually all day things, from about 9 am to 2 or 3 in the afternoon. We ain't fast but we get 'er done. :wink: Plus, you're going to need time in the afternoon to get an alignment. No sense in tearing up your tires riding back to SRQ out of alignment.
    I hate to say it, but weekends are probably your best bet. Can't speak for everyone though so if they can figure out a way to do it on a weekday after the trail clean up, I'd be open to it.
  14. May 1, 2015 at 9:10 PM
    #1814
    Taco No Baka
    Lee
    Tampa, FL
    BTW, Mike, you ever figure out what was going on with your floor jack?
  15. May 2, 2015 at 5:16 AM
    #1815
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Not really but later that evening Rick & I helped my wife's uncle drop his gas tank & replace his fuel pump. Damn thing seemed to work fine then, my wife's uncle did add a little fluid to it though. That was probably the problem.
  16. May 2, 2015 at 7:46 AM
    #1816
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    I'm down for a lift day if I'm not workin or out of town, btw mine is one of the trucks that got lifted at mikes, also srq taco, I recommend you paint your spindles beforehand to fight off the rust, cause the non coated part will rust instantly, also for those of you that care, I'm in philly for a wedding of course :)
  17. May 2, 2015 at 8:04 AM
    #1817
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I care buddy & I'm not surprised your at a wedding.
    I swear your a wedding singer or planner.
  18. May 2, 2015 at 3:52 PM
    #1818
    SRQ Tacoma
    SRQ Tacoma Member
    Dalton
    Sarasota
    2013 MGM DCSB
    Paint the spindles, heard. Any particular product I should use?
  19. May 2, 2015 at 4:14 PM
    #1819
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I just used regular Rustolium, gloss black & red on the logo.
  20. May 2, 2015 at 4:54 PM
    #1820
    SRQ Tacoma
    SRQ Tacoma Member
    Dalton
    Sarasota
    2013 MGM DCSB
    Does rustoleum come in bright neon green? :bananadance:
