Tamper Resistant nutz & boltz for LED light bars, etc
Discussion in 'General Automotive' started by XXXX, Feb 24, 2014.
  1. Sep 30, 2014 at 9:48 AM
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    Another thing to do with Hex button heads would be to fill the hex portion with something that you wouldn't mined taking time to remove but a criminal would (caulk, solder, etc).
    I wouldn't trust anything on the threads like solder or glue... it will most likely fail when torqued.
  2. Sep 30, 2014 at 10:00 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I could do that. maybe ill just try that.
    for the roof mounts though, they are regular ol' bolts.. so ill need either hex for those, or security.
  3. Sep 30, 2014 at 10:01 AM
    Large
    Large Red
    Def not on the threads, I meant on the head of the bolts
  4. Sep 30, 2014 at 10:02 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i knew thats what ya meant :thumbsup:
  5. Oct 13, 2015 at 1:23 PM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Bringing back a year old thread...
    Do you have a link to said fasteners? Also, would I be able to not buy them in bulk?
  6. Dec 12, 2015 at 5:44 PM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    One link below for breakaway nuts (sounds much more painful than it is) and one for breakaway bolts. Either one can be a pain in the ass to remove. I realize that's kind of the point but take into consideration that you're likely to have to do some grinding/cutting/drilling if you want to remove them.
    http://www.tamperproof.com/categories/breakaway-nuts-non-removable.html
    http://www.losspreventionfasteners.com/store/products/tork-bolts/
    Your best bet for not buying in bulk would be a local fastener supplier but even they sometimes have minimum orders. For your location, maybe try these guys:
    http://www.bhjbaycity.com/
  7. Dec 21, 2017 at 5:43 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Yup....resurrecting an old thread...
    Rigid D series
    Carriage bolt 5/16-18
    Allen heads M6x20
    Is this correct?
    Thank you
