Tan softopper on gold dc?
Discussion in '1st Gen. Tacomas (1995-2004)' started by johnboyTRD, Feb 25, 2014.
  1. May 9, 2014 at 7:11 AM
    johnboyTRD
    johnboyTRD [OP] Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Someone else I'm friendly with here did theirs with a grinder. I assume w/ cutoff.
  2. May 9, 2014 at 7:21 AM
    capturecolorado
    capturecolorado Well-Known Member
    Alex
    Grand Junction, CO
    01 4Runner SR5 with some things attached
    I used method, but in the future I'm going to use a longer (like, maybe 32") scrap piece of 4" plate, because of the shape of the bedside you're unable to drop the tape straight down to your marking point, which I think makes your line a little wonky. Otherwise mask it off where you think you'll be cutting, mark pencil lines every 3" or so, then if you can find a good, flexible straight edge (doesn't make sense...), connect all the marks. The corner is the hardest, so maybe mark lines closer and fill them in free hand.
    Then mark it off with sharpie for a clear and easy guide when you get to cutting. As far as what I used to cut, I don't like using sawzalls, they're too violent, so I used a 4.5" angle with a fresh wheel, it sort of melted through the fender, but did fine. The corner and behind the fender were the hardest - there's an absurd substructure beneath the tail light (make sure you've got the wiring harness moved out of the way), a long sawzall blade would be useful there to get in deep, but I didn't have one handy, so I had to use a dremel and slowly trim it away.
    Otherwise hit it with some paint, throw door trim on it, and you're set. If you're still concerned with rust, you can run a super thin bead of RTV inside the door trim before you put it on and call it good. I might do that eventually myself, but the door trim fits really really tight, so it might just be a moot point.
