Tandem Mountain Bike
Discussion in 'Buy / Sell / Trade - Other' started by PMK, Apr 17, 2012.
  1. Apr 17, 2012 at 7:42 PM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    2010 Fandango 29r Tandem Mountain Bike
    Injury Forces Sale…Our favorite tandem, but we must sell it.
    Frame was bought new in July of 2010. Bike build was completed 08/2010.
    Bike is built for true cross country off-road riding. The drivetrain is a 2x9 setup with a guard in place of the outer chainring.
    Build components are high end and tandem rated.
    Frame is size large (19,5 / 17.5), Frame color is white
    ATC double crown fork, (converted to wet lube system, reliable coil spring, no flex)
    Shimano Tandem Crankset
    Middleburn hard anodized and Teflon coated chainrings
    SRAM 991 Cross Step drive chain
    SRAM 971 Timing Chain
    SRAM PG 970 Cassette, 11/34 tooth
    Rear Derailleur, SRAM XO twist
    Front Derailleur, Shimano SLX 2x9 specific
    Brakes, Avid BB7 with 203 mm discs, (recent new Avid oem brake pads)
    Brake Levers, Avid Speed Dial SL (titanium hardware)
    Front Wheel, DT 440 hub, DT Alpine triple butted spokes, Sun MTX 33 rim
    Rear Wheel, DT 540 hub, DT Alpine triple butted spokes, Sun MTX 33 rim
    Tires / Tubes, Panaracer Rampage and Slime tubes front and rear
    Easton handlebars, Thomson Captain stem, CODA adjustable stoker stem
    FSA PIG Headset
    Seatposts, Captain-Thomson, Stoker Thudbuster LT with Lizard Skin dust boot
    Saddles, Captain, Terry Fly Titanium, Stoker, Terry Butterfly Titanium
    Pedals Shimano SPD M520
    Eccentric Bottom Bracket, Bushnell
    Also includes two custom frame bags and three Profile Bottle Cages.
    Bicycle has 120 miles since replacement of all chains, chainrings, cassette, cables and cable housings. Additionally, both bottom brackets were removed and inspected. The Eccentric Bottom Bracket was removed, inspected, cleaned relubed and reinstalled. Scott grips and new XO shifter grips also replaced.
    Bike is setup for Captain 5”10”, Stoker 5”6”.
    Frame Dimensions * 19.5/17.5 (From MTBTandems.com Website)
    Captain's TT: 24.5 "
    Captain's ST: 19.5"
    Stoker's TT: 28.6 "
    Stoker's ST: 17.5"
    BB Height: 13 inches
    Standover: C = 31", S = 28"
    $3500
  2. Sep 4, 2012 at 9:46 PM
    M Facchini
    M Facchini New Member
    Hi PMK,
    My wife and I are interested in purchasing your Tandem Mountain Bike. Would you take $2500, as we will need to have it shipped to San Diego, CA (the other coast).
    Thank you,
    Marc
    858-414-8556
  3. Sep 5, 2012 at 6:07 PM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    That is a nice bike. I have never seen a true off road tandem. GLWS
  4. Oct 15, 2012 at 9:33 PM
    davidk0
    davidk0 Well-Known Member
    sacramento
    95 SR5
    lol that will not work for where we mountain bike!
