Tank strap modification for gas tank skid plate mounting to non-TRD Off Road trucks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew61987, May 15, 2017.
  1. May 15, 2017 at 3:44 PM
    andrew61987
    andrew61987 [OP] Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Wasn't able to find a lot of info on this so I jumped in and discovered it's an easy mod. No need to spend $$$ on TRD gas tank straps with studs. This cost me $8 of hardware and an hour or so of work. The tank has large divots right where the bolt heads go.
    Tips:
    Make sure you support the tank with a jack when removing the straps. Do them one at a time.
    Check your measurements to ensure you're drilling your strap holes in the right spot and that the holes in your skid plate will line up. You can see that I had to drill one of my holes off center.
    Use interior tooth lock washers plus regular washers on the bolt head to help it grab when you start tightening the nut as you will not be able to hold the bolt with a wrench.
    I used four 3/8" x 1-1/4" standard bolts in addition to the two frame bolts provided with the skid. You might be able to get away with 1" long bolts but it will be more difficult to get the nut on the bottom of the plate. Buy both lengths when you make your hardware store run because you might want to try each.
    Drill 1/2" holes in your straps and use washers on your 3/8" bolts. This will give you some room to move the bolt around when you try to get it through the skid plate hole.
    See pictures:
    Front strap with off center hole. Bolts with lock and regular washers.
    Tank with strap removed showing divots.
    Finished product. If you use 1" bolts they won't stick down so far but it will be more difficult to get the nut on.
  2. May 15, 2017 at 5:28 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The skid obviously works for the OPs needs. Just as the silly stock skid works for your needs.
    Good on ya for putting this out there @andrew61987 I'm sure it'll help someone.
  3. May 15, 2017 at 5:41 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Nice work OP. I know a lot of people aren't aware you can do this cheap mod and are spending the 150+ on the Off Road OEM straps with the nuts on them.
  4. May 15, 2017 at 8:58 PM
    Pistolpetetacotreat
    Pistolpetetacotreat Well-Known Member
    West coast
    2011 DCLB sport
    OME 3" w/ front top spacer Leds BR mounted on retractable tonneau Cbi bump 285's
    Nice job. Though in a perfect world I'd prefer to see a slight recession in the skid to allow the bolt head to be at the same height as the main flat skid. You think without the front strap bolts it would really drop/sag being it's aleady secured on the frame?
  5. May 15, 2017 at 9:26 PM
    andrew61987
    It wouldn't sag, but if it does take a hit I'd rather any lateral force that doesn't go to the frame get transferred to both straps instead of just one. Plus I'm not one to leave provided bolt holes empty.
  6. Dec 13, 2017 at 11:51 AM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Good Post. at Budbuilt he offers gas tank skid plates and also offers what he calls "Beefy Strap" for those of us with no factory skid plate. He gets $75 for this bracket (in addition to the skid plate in steel, stainless steel or aluminum. I am one of the guys who need this mod or to buy the tank strap from Toyota or the Budbuilt version. So yes, I appreciate your post!
    I was originally hesitant to let the back of the skid plate be supported by the tank strap (and thus, to a degree, the tank itself). But your explanation of the tank skid not being meant o support the whole truck but just to defend against puncture makes sense. Plus the front skid mount bolts (2 of them) do bolt directly to frame cross-member.
    Paint6it9black likes this.
  7. Dec 13, 2017 at 12:50 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
  8. Dec 13, 2017 at 12:54 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Same skid...but I drulled some holes and welded bolts into the strap.
    One gets creative when on a college student budget.
  9. Dec 13, 2017 at 5:23 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I need to do this. I pucker when going over sharp rocks. Years back, I ripped a hole in my Mazda b2300 tank (ended up tying a sacrificial sheet of aluminum to the new tank)
  10. Aug 23, 2018 at 3:27 AM
    Paint6it9black
    Paint6it9black Well-Known Member
    Rob
    Easton, Pennsylvania
    2011 Tacoma TRD Sport
    OME 3" lift in front Extended Kings in rear Dakar leaf pack Shackle Flip 1” body lift All-Pro front bumper All-Pro Apex rock sliders Kore 4x4 Custom HC rear bumper Window Tint 5% Mesh Grille (homertaco) Rigid Industries led fog lights Fog light anytime mod Rear Diff breather mod CB Radio Safari Snorkel Home Made tire carrier (not by me) 37's Cut, Bashed and Dented Freedom SS pillar lights Smittybilt x2o 10k winch synthetic U-Bolt Flip RCI Full Skids 2" cut off fenders Front and Rear ARB lockers Geared 4:88 On board air with 2-1/2 gallon tank Relocated cab mounts
    Cheapest I found is on Rockauto. Offroad straps for like $47.
