Tankless Water Heaters???
Discussion in 'Garage / Workshop' started by Zac808, Aug 26, 2010.
  1. Aug 26, 2010 at 9:00 PM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I just found that my gas water heater is leakin internally. It's about six years old. Anyway I went to Home Depot to check out their tankless heaters. Between the federal rebate and local rebate I think tankless is the way to go. Does anyone have a tankless heater??? Or even installed one??? I'm thinking of doing it myself.:cool:
  2. Aug 26, 2010 at 9:07 PM
    jesseunvoas
    jesseunvoas Well-Known Member
    Jesse
    Swift Current, Sask, Canada
    08 TRD SPORT
    3" Ready Lift Super 80 Muffler AFE Stage 2 CAI Pro Dry Filter OEM Roof Rack RollBAK Tonneau Cover Cooper AT3 Tires Kakays On The Roof free candy topper
    you can do it yourself if you follow local regulations we got one in the house. needs to be on the exterior wall vented properly and in the correct location* not by any windows or doors. highly recommend saves money in the long run
  3. Aug 26, 2010 at 9:13 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    yup, what he said, they will save you cash and its much better for the environment
  4. Aug 26, 2010 at 9:15 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    got one that was put in during new construction. love it. continuous hot water...and my gas bill has onlt been like $14-16 a month (only thing on gas). just like a regular water heater, it takes a few moments to get warm. ours is on the outside of our garage on the wall and the digital controller is inside the garage.
  5. Aug 26, 2010 at 9:19 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Thanks for the response. I wanted to put it in the same location as my current heater which is in the corner of the garage. There is a vent tube hooked up to my original heater that I was going to use for the tankless system.
  6. Aug 26, 2010 at 9:21 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Tankless Heaters are great- The important thing is to get the right size.
    Depends on the size of your family and seasonal variation of the temperature of the supply water. Seeing as you are in Vegas- I bet the water is not much colder in the winter than the summer. Your main concern is if you are going to have 3 people wanting to shower at once or something like that. Make sure to get one that is large enough for your household needs. You may have to pay more for the initial heater, but should realize savings on gas within a year or two.
  7. Aug 26, 2010 at 9:55 PM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    OME 885x coils, 5100's set at 0. Deaver 2" AAL and 5100s out back. AFE Pro Dry S drop-in, BHLM, '10 sport grille.
    Eef, I'm going to have to disagree. If you're only needing the heater for one sink (like just for a shop sink) or any application that will have little use - then I'd say go for it. Most tankless heaters use a lot more energy to get you that hot water on demand and compared to an efficiently maintained and regulated HWH, it will be a bit MORE expensive every month. A couple options I'd suggest - replace with a regular tank and put a blanket on it (i.e. fiberglass insulation) or replace the tank with a Marathon (do some googling, they're LEGIT... but pricey) and either way you go install a timer on it so the water is only heating when you need it. Most hot water heaters run every hour and you if it's electric - figure there went $.25-50 every time it kicks on and typical insulation is terrible in the tanks so the heater constantly has to turn on to keep the water in the tank hot. The marathon when heated to 120 degrees - only loses 2 degrees over 23 HOURS!
    We sell the Marathon heaters at work (no I'm not a salesman LOL) and now are doing a solar hot water heater program - I actually have in mi casa ;)
  8. Aug 26, 2010 at 10:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I had a training seminar on these awhile back. From what I remember, here are a couple things to consider.
    You need 3/4 inch gas pipe all the way from the meter to the tankless heater. Also, needs to be flushed every year to keep the heat exchanger in good shape. There is also a slight delay in getting hot water when you turn on your tap or shower. You can't use a recirc pump with a tankless either, as that will cause the heat exchanger to age rapidly, and voids your warranty.
  9. Aug 27, 2010 at 6:44 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Anyone have opinions on electric tankless WH's? My subdivision is all electric (DAMN YOU BUILDER, THE NEIGHBORHOOD ACROSS THE STREET HAS GAS!)
    I would like to ditch the big tank to save space in my garage. Again, complaint for the builder, he put the water heater in the left corner of the garage so the biggest thing you can park on that side is a mid-sized car.
  10. Aug 27, 2010 at 6:55 AM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    Well it looks my advice might not be as relevant considering I was referring to electric. I can't speak at all on the efficiency of a gas unit.
    Macgyver, my previous advice definitely applies to you :laugh:
  11. Aug 27, 2010 at 7:00 AM
    macgyver
    Brad
    Canton, GA
    Ah yes...Thanks
    hmmm...decisions....Space or energy efficiency....that is the question! I could care less about the hot water on demand. My tank heater actually heats up pretty quickly. My garage is insulated and I keep it heated during the winter time (haha even in our mild GA winters :D) so do you think the blanket would make much of a difference? I may check into one of those timers since the WH doesn't get used during the day. Thats a good idea since I already have my thermostat programmed on my HVAC, why not do the same for the WH.
  12. Aug 27, 2010 at 7:05 AM
    Everbody
    Everbody Well-Known Member
    Central CA
    05 PreRunner SR5 TRD 2wd
    Looks stock
    Consider solar water heating!
  13. Aug 27, 2010 at 7:10 AM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    A wrap on your heater would absolutely still help. And the timers are great as well - you can use a pool timer or they have water heater specific kits that range in technology from a rotating dial that you just adjust the "pills" or digital timers like your HVAC control. I've got a buddy with a 3600 sq ft. house with an attached 1100 sq ft garage - when he had the house built he had both a/c and swamp coolers run through the duct work and his garage is very well insulated and has hvac vents... that said - when he installed his blanket and timer his power bill went from $4xx range to $2xx range.
    Or for people who are looking to change out their tank and willing to spend a little money now to save a little money every month - check this out.
  14. Aug 27, 2010 at 7:11 AM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
  15. Aug 27, 2010 at 9:16 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Yeah, I would need to get it changed to a direct vent system. And also need to have a 1" line installed off the meter. $2800 install over four days is not worth it for my current living situation.
  16. Aug 27, 2010 at 9:20 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Thank you all for the great responses. This is why TW is so awesome. I'm gonna stick with the tank style because of cost and I need it done today. But mainly COST. LOL.
  17. Aug 27, 2010 at 12:04 PM
    The_Hodge
    SC
    glad i only paid $400 when my house was built for mine.
  18. Aug 27, 2010 at 3:31 PM
    abenaki
    abenaki Member
    My two cents... had tankless systems when I lived in England and Ireland for over 8 years.... buy one... good stuff!
  19. Aug 27, 2010 at 3:44 PM
    blackwidow2009
    blackwidow2009 Well-Known Member
    Brian
    Cleveland
    09 Access Cab 4X4 TRD w/ SR5
    2.5" front lift Daystar coilover spacer. 2.5" rear lift add-a-leaf N-Fab wheel to wheel nerf/step bar Polished Stainless Leer cap from my 2000 Tacoma --- It does fit; don't let them lie to you
    yes, my cousin installed one...it rocks!!! but be carful...they really can burn you!!! they are very, very efficent, so they cheep to run. but usually they are very expensive to buy, but if your getting rebates and tax insentive, that may level the playing field with cost. Personally, I'd say go for it.
  20. Aug 27, 2010 at 8:24 PM
    OmegaMan
    OmegaMan Well-Known Member
    The Woodlands Tx
    2010 DC TRD Offroad
    Front window tint, Silver Star headlights and Fogs. Katzkin Leather Interior, Heated seats, UnderCover bed cover, JVC DVD HD radio + NAV
    We have had a tankless water heater since early May.
    http://www.rinnai.us/
    I would stay away from anything you get at home depot or Lowes. We have a unit that can put out 9.4 GPM of 140 degree water and if you swap out the circuit board, it will do 180 degrees. :eek:
    Make sure you can get 3/4 " gas to the unit, make sure you can properly vent the unit and make sure you have 110 AC close by the unit as it needs the juice to fire up the ignition for the gas.
    I am only paying for has when the hot water tap is open as opposed to keeping a 40 gallon container hot at all times.
    Tankless is the way to go.
