Tap into satellite antenna.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hippie, Jul 4, 2013.
  1. Jul 4, 2013 at 9:55 AM
    hippie
    hippie [OP] Member
    indiana
    09 trd sport
    help, im not real good at this.... but i found a thread that shows you were the sat. connection is. i have an 09 dc. its in the drivers kick panel. the thread said you need to buy this 70 dollar adapter. i just installed an alpine bt145. it came with a Sirius tuner. couldnt i just splice the antenna lead into the wire that comes off the back of this plug and use the factory installed antenna?
    thanx for all ur help,
    hippie:D:D
  2. Jul 4, 2013 at 10:04 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If that adapter is just that, a plug adapter, you should be able to just splice it.
  3. Jul 4, 2013 at 3:21 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Couldn't you just have an adapter that plugs directly into the new unit and the factory plug for the factory head unit that has the sat tuner? I have used a few that I bought from Crutchfield and they plugged in perfectly to the factory system. Not with this truck though so it might be different?
  4. Jul 4, 2013 at 3:43 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    NO! You CANNOT splice that wire together. Your antenna will not work if you do that (if it does it won't work very well) Sat antenna cables are EXTREMELY sensitive and cutting and trying to solder it together will run you a very very high risk of failure. I have tried and failed more than once. This is the reason that stupid adapter is $70 because its the only option.
    On another note, I have an 09' and my junction is in the passenger kick panel :confused: are you sure its on the driver side? Have pics?
  5. Jul 4, 2013 at 4:28 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Sat antennas have receive amps inside they are powered through the antenna wire and use microwave frequencies far higher then the truck antenna is designed to receive. No cut and paste.
