tapered block ??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bolt_thrower77, Apr 9, 2021.
  1. Apr 9, 2021 at 6:01 AM
    bolt_thrower77
    bolt_thrower77 [OP] Well-Known Member
    2021 DCLB trd or
    so i bought the set of trd lift shocks which will give 2" in the front. for the rear i wanted to get a little more than level so i went with a 1.25" block.
    the block is tapered so it goes from 1.25" to 1.125" ....or about 1/8" drop
    my question is...am i going to need some type of suspension shims?...or should i expect it to sit flush on the block or have gaps or what?....
    i'm just trying to figure this thing out before i get it all tore apart...any help is greatly appreciated
    thanks!
  2. Apr 9, 2021 at 6:19 AM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    It's to keep a decent pinion angle when lifting. Put the thicker end toward the back of the truck and it will point your pinion a bit up towards the transfer case. Although on anything with a wheel base longer than a wrangler that taper isn't as critical.
    Crikeymike likes this.
  3. Apr 9, 2021 at 7:08 AM
    bolt_thrower77
    2021 DCLB trd or
    so .... to be clear.....i probably shouldn't need shims?.....also, i do have the long bed so not sure if that affects anything?
  4. Apr 9, 2021 at 7:10 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Correct no shims needed. Just install as mentioned above.
  5. Apr 9, 2021 at 7:14 AM
    bolt_thrower77
    2021 DCLB trd or
    thanks dude :)
