taping under dash
Discussion in '1st Gen. Tacomas (1995-2004)' started by STeeCHfinger, Jun 20, 2011.
  1. Jun 20, 2011 at 6:23 PM
    STeeCHfinger
    STeeCHfinger [OP] Member
    It dosent always happen but every now and then there is a tapping from under my dash, it will usually happen at around 50-70 mph. i just cant locate the exact spot when im driving. Its a 02 double cab V6 TRD prerunner , automatic. any ideas?
  2. Jun 20, 2011 at 6:31 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That's the speed troll... Take his hammer away and he'll quiet down.
    But, seriously, look for loose hoses, wires, trim, fenders, flaps, etc.
  3. Jun 20, 2011 at 8:10 PM
    STeeCHfinger
    The truck had a trailer brake controller installed in it when i got it could that have anything to do with it
  4. Jun 21, 2011 at 5:30 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    Funny! I think I have the same problem. Mine sounds like rats climbing around in the dash. I would like to think it's a rattle with bumps, etc, but it seems it just does it at highway speeds. Of course, there are many other rattles, but that one is the most aggravating!
  5. Jun 21, 2011 at 6:06 AM
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    Does your speedo jump around also? Might be the speedo cable. Had that problem in my old truck before the cable broke
  6. Jun 21, 2011 at 9:46 PM
    STeeCHfinger
    a mouse under the dash would be exactly how i would describe it, I dont have any speedo jump and i was thinking the cable. Its very weird
  7. Jun 21, 2011 at 10:04 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I think there's a motor of some sort on the passenger side that people have tightened the bolts on that have gotten rid of dash rattles. I would try that out. Where at around the dash is the noise specifically coming from?
  8. Jun 21, 2011 at 10:51 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    i have a similar issue. it likes my keys are hitting the plastic panel, but if i hold the keys while i'm driving, the tapping is still present. i'm pretty sure it's something loose under there, but i'm haven't had time to take things apart to investigate.
  9. Jun 22, 2011 at 3:56 AM
    bicklebok
    Ronnie
    Montgomery, AL
    Steech, is yours on the passenger side? Mine is. Only does it at highway speeds. Kmok, do you know what motor it is that needs tightening?
  10. Jun 22, 2011 at 9:02 PM
    STeeCHfinger
    mine is just like scwerks sounds like the keys hitting but when i hold the keys or just have ignition key in, it is still there. it sounds like its right under the dash on the bottom center or just to the right a bit around the ignition switch
  11. Jun 22, 2011 at 9:05 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Mine makes a clicking sound from the airbag on the passenger side. Not the airbag itself but like the cover slightly moving in the separation around it. If i wedge my finger in the crack it stops.
  12. Jun 24, 2011 at 9:17 PM
    STeeCHfinger
    I wish i could stop it, some times i just want to kick the dash, but i know that will do nothing but break something else, and ill have to fix that!.... I would just like the tapping to stop.
  13. Jun 24, 2011 at 11:29 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    lol, i'm constantly driving with one hand resting on something trying to locate the loose part. i think the only way to find out is to actually take everything apart around the dash area.
  14. Jun 25, 2011 at 12:26 AM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    I had the same problem. Ended up finding that the rubber "engine guard" attached to the lower edge of the driverside front inner wheelwell had come loose and the free end was flapping around, hitting the fire wall. Some of the plastic "panel rivets" had come out. Got new ones from the stealer, popped them in, no more noise.
  15. Jun 25, 2011 at 1:10 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    ^^^ This! Same happened to me and I sware it was inside the dash. I wasn't even missing any rivets. They simply become loose and with enough wind going over the rubber at highway speeds it makes the rivets clickity clack. I went to home depot and got some half inch self tapping screws with rubber washers and the tightened the flaps down. Good to go!
  16. Jun 25, 2011 at 3:14 PM
    STeeCHfinger
    I am going to check it out, cuz that sounds logical to me
  17. Jun 26, 2011 at 9:58 AM
    STeeCHfinger
    ok so the splash guard was off at 1 part it was ripped the plastic rivet was their but the rubber was torn. I think this is a job for the magical tool duct tape..lol will let you know if it works
  18. Jun 26, 2011 at 10:24 AM
    bicklebok
    Ronnie
    Montgomery, AL
    Hope it works for you. Havent found mine yet. I opened the glove box driving yesterday and the noise got louder. Im gonna have to get behind the glove box and chase mine down.
  19. Jun 27, 2011 at 4:24 PM
    Wile
    Tim
    New Mexico
    Hope that fixes it!
  20. Jun 28, 2011 at 5:08 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Duct tape won't hold up. The rubber glue hardens, and the vinyl backing separates. You'd be better off with staples, riveting in a repair piece, or a new guard.
