Tapping into the dome light?
Discussion in 'Technical Chat' started by Rucas, Dec 26, 2010.
  1. Dec 26, 2010 at 8:44 AM
    Rucas
    Rucas [OP] 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    So I got some LED strip lights and I wanted to put them in the foot wells of the truck. I want them to be activated whenever the dome light comes on, so like when the doors open, and close they turn on and off.
    Any help is appreciated.
  2. Dec 26, 2010 at 9:02 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    You should be able to find the info you need through a search. I took off my dome light and brought to the hardware store to find the right bolt to go through and secure it, others I have seen solider it on.
    [​IMG] [​IMG]
    I did mine very similar to this but with the bolt the other direction, if you do it this way just be careful to get the shortest bolt that will work for you otherwise it will contact the roof and make the lights turn on (ask me how I know).
    Some useful information in this tread (mines post 233).
    http://www.toyotanation.com/forum/showthread.php?t=91499
  3. Dec 26, 2010 at 9:08 AM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    Yeah i tried searching a little, but came up blank on many threads. (haha i do know how so search)
    So all I would need to do is tap connect the wire to the positive terminal of the dome, and then ground the lights? and they should work together?
  4. Dec 26, 2010 at 9:12 AM
    mach1man001
    Rob
    Blackstone, MA
    Well thats all there is involved in doing the map light mod. I haven't added other lights this way so I don't want to say. Try to keep looking up others to see what they have done and possibly fusing it as well. Good Luck.
  5. Dec 26, 2010 at 9:21 AM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    alright thanks. the lights are 12volt -so I shouldnt have to use fuses right?
  6. Dec 26, 2010 at 9:22 AM
    maconhurler
    maconhurler Well-Known Member
    Harrisonburg, VA
    04 4wd v6 sr5
    Deckplate Mod, Catz Fog lights, Roll Top Tonneau Cover, Pioneer Premier 800prs HU, 10" Kicker L7, Kicker 5 1/4 components, Polk dB 5x7s, Oznium superflux puddle lights and bed lights
    I ran my wires in the roof and soldered into the backside of the bulb contacts in the dome light. Was a pain in the butt to solder as the solder didn't want to take but I got it and it works great.
  7. Dec 27, 2010 at 2:34 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
  8. Dec 27, 2010 at 5:22 PM
    btuner
    btuner <<<<>>>>
    Brandon
    Hendersonville NC
    09 PreRunner SR5
    Stage III TRD Badge
    You could have just tapped into the blue control wire in the A pillar and then they turn on whenever you unlock/have a door open.
  9. Dec 27, 2010 at 9:38 PM
    mach1man001
    Rob
    Blackstone, MA
    That came out very nice.
  10. Dec 27, 2010 at 9:39 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    :eek::eek:
    If only you told me that earlier....
  11. Dec 27, 2010 at 9:45 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    that is the best way to achieve the fade in/out
  12. Dec 27, 2010 at 9:48 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    maby ill have to move it so it taps into there. the wires are already running up the A pillars so it shouldnt be that hard. plus i feel safer with them there instead of connected to the top of the dome.
  13. Dec 28, 2010 at 5:07 AM
    btuner
    btuner <<<<>>>>
    Brandon
    Hendersonville NC
    09 PreRunner SR5
    Stage III TRD Badge
    Yeah just run one wire to a constant power source, ie the battery, and tap the ground wire to the blue wire in the A piller. It's really easy but took me a while to figure out as well.
  14. Dec 28, 2010 at 8:42 AM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    shouldnt there be a live 12v power wire somewhere in the a pillar too? so i dont have to run the wires to the battery?
