Tapping noise coming from back right of vvti cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Double R, Jun 6, 2025 at 10:43 PM.
  1. Jun 6, 2025 at 10:43 PM
    Double R
    Double R [OP] New Member
    Friday
    Jesse
    2008 2.7 tacoma
    New timing cover, water pump, cluch fan, vvti solenoid, and top timing chain guide
    Theres a tapping sound coming from, about 3/4 of the way back on driver side in the valve cover and when im accelerating the sounds turns into almost a whistle/claddering noise. Long story short before i found where the sound was coming from, I've replaced the timing cover, water pump, cluch fan, top timing chain guide, spark plugs, one of the coils, and the VVTi solenoid. It's got to be the VVTi gear or valve, something?? Please, someone help me! I've been at this for 2 weeks now.
  2. Jun 11, 2025 at 10:53 PM
    Owenhall
    Owenhall Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    Can’t really give an answer but maybe check valve lash with a feeler gage.
    on my Tacoma the hood label has the clearance specs.
  3. Jun 11, 2025 at 11:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Could be a valve noise. Like a broken spring or bent guide, etc
    Do a compression test out of curiosity
    Take the valve cover off and rotate the engine, look for something binding in the valve train or see if a valve is hanging open
    Does it do the noise constantly whenever the engine is running?
