Tapping Noise from Passenger Dash Speaker (SOLVED)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Haikin, Mar 16, 2016.
  1. Feb 26, 2018 at 9:46 PM
    #141
    Mooseman537
    Mooseman537 Well-Known Member
    Jim
    Pennsylvania
    2017 MGM Tacoma OR
    I’ve had the same problem and only when it’s cold! Here I thought I was just nuts and hearing things!
    tonered likes this.
  2. Feb 27, 2018 at 10:37 AM
    #142
    Ex03
    Ex03 Well-Known Member
    2017 Red Tacoma TRD Sport
    So I also have this problem. I have attempted to smack the shit out of the pillar. It moved forward. Going to drive it later today to see results. I have also put special noise reduction boards in the cab to install if needed. Business Cards......
    Taco_310 likes this.
  3. Feb 27, 2018 at 1:35 PM
    #143
    Ex03
    Well after the drive there is no sound anymore. I assume overtime the pillar will slip back out of place and that could be a problem with the sound coming back. I will keep an eye on it and smack the shit out of it as needed.
    -RK
    Taco_310 and Riding Dirty like this.
  4. Feb 27, 2018 at 4:04 PM
    #144
    axiomjunglist
    axiomjunglist New Member
    2017 Metallic Grey Tacoma
    None
    I really can't believe I signed up just for this noise (no pun intended), but here I am. I've been driving around with a business card shoved between the pillar and passenger speaker grill for about 6 months. It doesn't bother me but my GF thinks it looks ghetto, my friends always ask why it's there, and in the end after paying $40k+ for this truck I agree it shouldn't be making such an irritating noise without a 'business card fix'.
    Anybody try to shim a small square piece of felt in that crack without prying apart anything first? I was going to try taking it to the dealer but after reading this thread it sounds like a terrible idea...
    I still can't believe this thread has 8 pages...
  5. Feb 27, 2018 at 4:12 PM
    #145
    Ex03
    You think that is bad this isn't the only thread. My thoughts on a terminate solution would be to shave down or aggressively put in a felt tape between the two sections. Or when in doubt smack the shit out of it.
  6. Feb 27, 2018 at 8:24 PM
    #146
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    Really, this is the simplest fix ever to an annoying problem. If the business cards or toothpicks truly stop the rattle. Pry the A-pillar bolt covers loose. A thin plastic trim tool is helpful but not needed. Remove the bolts and wiggle out the pillar cover. You might consider marking your pillar cover with tape first so you can ID the trouble spot or angle of dash once the pillar cover is off. Then simply apply a strip of felt tape to the trouble spot and reassemble. Be aware of the air bag and the weather stripping. It’s easy to pull the speaker cover once the pillar cover is off if needed. It’s probably not needed unless you want to secure the auto dimming lights plug from beneath. The speaker cover lifts up from the cab side (away from the windshield) with a thin trim tool. Work carefully. This is an easy one. Really. You could probably also just slip something small in there without pulling the pillar cover but the felt tape should be permanent. Good luck!
    Ex03 likes this.
  7. Feb 27, 2018 at 8:34 PM
    #147
    Ex03
    Well said.
    rsimi72[QUOTED] likes this.
  8. Feb 27, 2018 at 8:40 PM
    #148
    tcjacado
    tcjacado Well-Known Member
    @shakerhood this is the thread for the door pillar
    shakerhood likes this.
  9. Feb 28, 2018 at 12:13 AM
    #149
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    I would disconnect the battery first since there is an air bag there..
  10. Feb 28, 2018 at 12:22 AM
    #150
    not0ny
  11. Feb 28, 2018 at 6:37 AM
    #151
    ToyoTacoTurner
    ToyoTacoTurner Am I really well-known?
    Houston
    2016 BBP TRD OFF ROAD DCSB 4x4 (OV TUNED)
    PRO GRILL-Meso lights-Speakers-rear black bumper-Debadged
    I actually also did it this weekend with the "loop" side of the Velcro. I used the "hook" side under some floor mats to keep them in place since all my passengers have a tendency to push them forward.
  12. Feb 28, 2018 at 9:37 AM
    #152
    axiomjunglist
    None
    Nice, I'll give this a shot, thanks! Also the reco on the hook side velcro for the passenger-side floor mat is ingenious. Every time someone rides with me that thing is all jacked up afterward...
    ToyoTacoTurner likes this.
  13. Feb 28, 2018 at 10:33 AM
    #153
    BigAirGar
    BigAirGar Well-Known Member
    Ont Canada
    2016 TRD Sport DCLB AT
    Liv Free Rock Hrd
    I've got this noise as well. Annoying AF !
    Thanks for posting this, i suspected it was from that area and have the tweeter upgrade on my to do's.
    That list just keeps getting longer btw
  14. Feb 28, 2018 at 10:52 AM
    #154
    ToyoTacoTurner
    Houston
    I had some extra "rough side" on the velcro and figured I would try. I haven't had any issues since. I used two 1" length strips on the corners closest to the seat figuring I would mimic the latches on the driver's side.
    Truly, the speaker upgrade should have the Velcro or pads on the pillar as a step. Its too damn easy and only helps avoid rattles if you were to ever add a sub.
    tonered likes this.
  15. Mar 1, 2018 at 7:10 AM
    #155
    ChadVKealey
    ChadVKealey Well-Known Member
    Philadelphia, PA
    2017 Silver Sky Tacoma SR5
    None (yet)
    My '17 SR5 started with this noise intermittently back around November and I've been putting up with it. After a 6 hour drive on Monday from Philly to Norfolk, I couldn't take it any more. Then I actually looked here and tried the toothpick "fix" (didn't have wooden toothpicks, just one of those combo toothpick/floss deals, so it looks extra odd). The whole drive home yesterday the noise was completely gone. Just to verify, I pulled out the pick before driving to work this morning and the noise immediately returned.
    When time and weather allows, I'll pull the a-pillar trim panel and add in a permanent shim (some felt tape or fuzzy velcro, if I can find my stash of that).
    I'm annoyed that a truck barely over a year old without even 8,000 miles had already developed "old car" noises. My '03 Focus had 75k on it before it had any kind of rattles, and that cost 1/3 what the Taco did!
    On the up side of the trip, I hit a new fuel economy record! Actually, a few minutes later, it hit 29.0 for the trip mileage, but that photo came out too blurry.
    rsimi72 likes this.
  16. Mar 1, 2018 at 7:17 AM
    #156
    c4ifford
    c4ifford Active Member
    Gen3 TRD
    none yet
    This noise has been bugging me the entire time I've had my '17, just had it in a few weeks ago for the 10k service. The tech said they couldn't replicate the noise.
  17. Mar 1, 2018 at 7:48 AM
    #157
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    I also had a rattle coming from the above centre console
  18. Mar 1, 2018 at 8:30 AM
    #158
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    This may sound crazy, but I think you're seeing symptoms of a non-broken-in rig.
    I bought mine in the fall of 2016. Last winter when it got cold, the dash had all sorts of squeaks in it. Reading up on it, several people had taken their pillars apart and modified the parts that showed rubbed marks. But it was just too damned cold to be working on it and of course last summer it didn't cross my mind.
    This winter the dash was dead quiet during those 0ºF mornings. With 25,000 miles on her.
    SB
  19. Mar 1, 2018 at 9:09 AM
    #159
    ChadVKealey
    Philadelphia, PA
    None (yet)
    The only problem is that it (mine, at least) was dead quiet until sometime last Fall. So, things from the factory are nice an snug...then loosen up and start making noise...then get even more loose and the noises go away? Maybe that's worked for you, but it doesn't seem logical to me.
  20. Mar 1, 2018 at 9:25 AM
    #160
    Sagebrush
    Gens 1, 2, 3, and 4
    Last fall was when it got cold, right? How many miles on your truck?
    SB
