Tapping power for USB ports in blank next to fog light switch - Finished.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dofartshavelumps, Jan 6, 2016.
  1. Jan 10, 2016 at 6:31 AM
    Stroonzo
    Stroonzo Well-Known Member
    Biscuits likes this.
  2. Jan 10, 2016 at 6:34 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    the 15amp fuse for the charger outlets is constant 12v, I used the ACC circuit so my lights go off when the vehicle goes off
  3. Jan 10, 2016 at 6:51 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Look at the pics below your original post. The white plug in the top right corner, black wire yellow tracer it is a constant 12 v supply. I tapped and soldered in this pin so didnt have add a taps hanging ariund when I installed my 3.1 amp charger similar to op that fit by my atrac button under ac controls.
  4. Jan 10, 2016 at 6:53 AM
    Mush Mouse
    mush
    2013 SR5
    me too I pluged into the 15amp slot first with my add a fuse and the fogs lit and had to use my switch for on/off, decided to use the ACC circuit so they goe off with truck:notsure:
  5. Jan 10, 2016 at 12:43 PM
    Gottafly
    Gottafly Well-Known Member
    Robb
    Charlotte, NC
    2009 Black Tacoma TRD Sport
    Where did you find your ground? Any pictures?
  6. Jan 10, 2016 at 3:17 PM
    dofartshavelumps
    dofartshavelumps [OP] Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    This is the only pic I have right now - I tried to circle it in red, there is a curved metal bracket with a 10mm hex screw in it and I just pulled that out and put a ring terminal on the ground and put it back together. You may be able to see it when you pull the small tray out to access the fuse panel.
    TRDSport10 likes this.
  7. Jun 27, 2017 at 9:29 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    This is exactly what I want to do because my phone is in the exact same location.
  8. Oct 26, 2017 at 7:40 PM
    Justbrian
    Justbrian Well-Known Member
    Brian
    Tulsa OK
    2014 TRD OR
  9. Oct 27, 2017 at 6:25 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    It's a seriously easy project. I think it took me 15 minutes from start to finish. Also, very useful especially if you mount your phone in that location for using GPS.
  10. Aug 11, 2018 at 10:57 PM
    Jultepod
    Jultepod Well-Known Member
    Oahu, Hawaii
    2013 Gray Tacoma TRD
    K&N cold air, Exhaust, rims and tires, 3" king extended travel coilovers and total chaos UCAs, rear diff breather mod, CBI off-road ditch brackets with Cali raised LED pod lights and painless wiring harness, 4xinnovations rock sliders, cab mount chop.
    This was a great tip. I ordered a Dule USB port from caliraised thinking it was a direct plug and play. Well needless to say I was sadly mistaken. This thread and your pix were awesome. Really helped me out. On mine I ran it to the empty slots in the middle dash. Was a bit of a pain in the ass since I was in a hurry and couldn't find out how to pull the center dash apart to get the wires ran. So I just ran some string through where I flashed some light and pulled the add a fuse line through. My switch isnt a direct fit like I thought and it's kinda ugly but works better than factory 20180811_174227.jpg 20180811_183259.jpg 20180811_184652.jpg
  11. Dec 31, 2018 at 12:08 PM
    Taco2011trdsport
    Taco2011trdsport New Member
    2011 TRD Sport DC
    Just bought the parts to do this mod and have a question about the fuses to use on the add-a-circuit.
    So in the add-a-circuit, you guys use the original 7.5A fuse(if I’m tapping into the ACC slot) and for the tap in fuse(top slot), what fuse did you guys use? 5A fuse?
  12. Feb 1, 2019 at 11:12 AM
    Geraldo's Taco
    Geraldo's Taco Well-Known Member
    2015 Pre-Runner
    Same question, sort of. Can I put a 10A in and use the 7.5A on top, or should I leave it 7.5A and use a 5A in the top slot?
  13. Feb 1, 2019 at 12:27 PM
    caribe makaira
    Caribbean, Puerto Rico
    Bottom slot is for original circuit...top for added one. There is a Max to the overall amps depending on who makes the contraption. Should leave original circuit at set OEM amps.
  14. Jun 7, 2019 at 1:57 PM
    jimthzz
    jimthzz New Member
    Jim
    California
    Prerunner, 2W SR5, shortbed
    I did this today. I plugged mine into the power fuse slot. 10-minute job. Always on has more appeal to me. Thinking of a dash cam but didn't want to hardwire. USB ports gives me options, like for a temperature gauge.
  15. Dec 21, 2019 at 11:38 AM
    #35
    prone2xl
    prone2xl Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
    sorry to bump an old thread but @dofartshavelumps how did you end up cutting the blue diode to have the lights turn off? I have searched and couldn't find your instructions on that if you listed any. thanks !
  16. Dec 23, 2019 at 5:27 PM
    #36
    dofartshavelumps
    NH
    Yea, I cut the diode - still working with no issues. I think there were 2 of them I had to cut. I think I pulled the cover off (pried it off) and then used small cutters. It was a while ago but I think that is what I did.
  17. Dec 25, 2019 at 2:00 PM
    #37
    prone2xl
    Mississippi
    Thanks guys.merry Christmas everyone! @dofartshavelumps and @Doughnut Spaghetti question. On your Add a fuse, you tapped into the accessory one that’s 7.5 right? What other fuse did u use for the USB port? I bought the mini kit like u showed on Amazon but went to do the mod today and realized i didn’t have the 7.5 fuse that would fit in the device. Also i didn’t know if it was ok to go up higher as in 10A since I’ve seen both in videos and on here. Confusing enough! Haha and if not to add even more. I can’t get that damn dash apart to reach that top row switch next to the fogs. There was some website but it doesn’t work anymore. :(
  18. Dec 27, 2019 at 1:46 PM
    #38
    prone2xl
    Mississippi
    Just did this mod today and I ended up using a 7.5A fuse for both as I learned u don’t want to go higher on the new item fuse than the original fuse amperage
    Muddinfun likes this.
  19. Dec 21, 2021 at 2:25 PM
    #39
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    2013 Tacoma AC 4x4 M/T 2.7L
    Sorry for the thread resurrection. Just wanted to thank TW fam, once again for the ideas. Finally can enjoy not using a USB extension wrapped around the driver seat!
    Doughnut Spaghetti likes this.
  20. Dec 21, 2021 at 3:16 PM
    #40
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    i connected mine to the old cigarette port and then added one to the fuse block i have so i can turn it on and off without a key
