Tapping sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hueysand, Aug 24, 2025.
  1. Aug 24, 2025 at 12:07 PM
    Hueysand
    Hueysand [OP] New Member
    Huey
    2011 Toyota tacoma
    2011 4.0L V6. So started getting loud tapping noise and found no oil! Anyway, read it might be timing chain issue but I have it down to timing chains off. Should I go ahead ant take the heads off to check the valves?
  2. Aug 24, 2025 at 1:03 PM
    haydendoesmith
    haydendoesmith Well-Known Member
    15 DCSB TRD Sport 4X4 Auto
    Loud tapping noise and found no oil? You sure it wasn't a rod knock?
    TnShooter likes this.
  3. Aug 24, 2025 at 1:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did you add oil and start it back up?
    You got nothing to loose at this point.
  4. Aug 24, 2025 at 1:24 PM
    Hueysand
    Huey
    2011 Toyota tacoma
    I’m not sure of anything at this point. ‍♂️
  5. Aug 24, 2025 at 1:25 PM
    Hueysand
    Huey
    2011 Toyota tacoma
    Yes. I filled it back up with oil and it still tapped.
  6. Aug 24, 2025 at 1:28 PM
    TnShooter
    Deogee
    STOCK
    In the engine world, You have taps and knocks.
    Knocks are always bad, taps aren't always bad.
    So, is it a tap or knock?
    Where does it sound like it is coming from? The top or bottom of the engine?
    Any video or audio?
