Tapping
Discussion in '4 Cylinder' started by labman626, Jan 10, 2013.
  1. Jan 10, 2013 at 4:35 PM
    labman626
    labman626 [OP] Member
    I have a tapping noise on really cold days. Oil level is fine and it does not last but a minute or two. Could it be the exhaust?
  2. Jan 10, 2013 at 4:48 PM
    JayC06
    JayC06 Well-Known Member
    Jay
    fairhaven ma
    06 4cyl ac 4x4
    5100's front at 1.75, procomp light bar, kc lights, dynomax muffler
    mine does too. i think they all do when its really cold
  3. Jan 10, 2013 at 4:53 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It's Ok. Keep your oil clean is 'bout it. [​IMG]
  4. Jan 12, 2013 at 3:46 PM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    You can put a oil pan heater on and use it under 30F. You can put it on a timer and have it set to turn on 4 or 5 hours B 4 you leave for work. No tap and U will get heat for your drive sooner. Or U can just live with it your choice.
  5. Jan 23, 2013 at 8:26 PM
    Steve E
    Steve E Well-Known Member
    Southern Missouri
    2014 TRD Sport DCSB 4x4
    My 08 2.7 does the same thing when it's real cold and the Stealership shop Manager said it was a cold start solenoid (whatever that is) and not a lifter. Hope he is right. LOL.
    Steve E........
  6. Jan 23, 2013 at 8:47 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Smog pump, more noticeable when it's colder.
    Mine "rattles" until the engine idles down.
