Taylor's Taco
Discussion in '1st Gen. Builds (1995-2004)' started by Taylor, Dec 27, 2013.
  1. Apr 7, 2014 at 8:44 AM
    #101
    Taylor
    Taylor [OP] Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Looks like my oil was really really gross. Maybe I'm being paranoid, or maybe I had mud in it. Anyway, I changed it. New purolator air filter in as well.
    Now, I'm wanting to get an even louder muffler, as the one I have now isn't noticeable at all unless I'm WOT at 3k RPM (Which sounds like pure SEX), which doesn't happen much in my truck. I want a deep rumble at idle to like 2.5k.
    I have an 18 inch Magnaflow center in, offset ouch, oval body on it now. Decided I'd go with the 14 inch, which I planned on getting originally, but I was worried it would be too loud. I went to look up some pricing on the 14 inch, and realized that the link I have saved from when I bought my current one says "Body length: 14 inches"
    Now, I have to wonder, did I buy the 14 inch? If so, this is WAYYY too quiet. I can't even imagine the 18 inch and how quiet it would be.
    I would crawl under my truck later today and measure it, but this rain is nasty, so we'll have to see.
    I also need to figure out something to mend the loss of exhaust note from me cutting off that last foot of exhaust piping out to the side exit. It seemed to have lost a lot of tone.
  2. Apr 7, 2014 at 7:14 PM
    #102
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Measured my muffler and it is, indeed, the 18 inch. Not sure what model, but that's good. Looks like I'll be moving up to a 14 inch with .5" bigger piping. I'll dump it after the axle.
    Also, a pic of me on the RTI ramp at the car show. I can't wait until I can get more suspension travel. The locker let me get higher than most on the ramp, but I don't think it counts because my tire isn't on the ground like it should be.
  3. Apr 8, 2014 at 6:56 PM
    #103
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    When changing my oil, I noticed a huge hole the width of a quarter and a dent the size of a baseball in my main skid. Looks like I need to upgrade soon. My frame and crossmembers are real scratched too. Guess it's good that they're there. Might need to take it easier until I can get more armor.
  4. Apr 8, 2014 at 7:01 PM
    #104
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    damn, something punch right through that haha. who ever won the toytec raffle at the show? i forgot to ask
  5. Apr 8, 2014 at 7:05 PM
    #105
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Me and Matt! There were 2 cards. Matt is the dude with that mall crawler looking second gen, haha. He won the show, because, let's be honest, his truck looks very nice.
  6. Apr 9, 2014 at 9:33 AM
    #106
    113tac
    Stephen
    Northern Virginia
    haha yeah i figured he was gonna win with his truck all done up. you gonna order your lift parts?
  7. Apr 9, 2014 at 3:57 PM
    #107
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    You should stray away from larger diameter piping, it actually takes away some power
  8. Apr 9, 2014 at 7:02 PM
    #108
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Called up Toytec and ordered my parts today! Had them shipped home, so hopefully they'll go on as soon as I get home in May.
    Also, I'm only doing the larger piping after the muffler, which won't affect it much, if it all.
    Also. I'll copy paste my Facebook status from earlier.
    The best badge. I peeled 3 of them. Kept 3 of them. 2 turned out "okay" enough to keep.
    Plasti-dip is hard. You'll also notice that I removed the Ranger badge, which means I only have one "extra" badge left, which isn't even noticeable.
  9. Apr 14, 2014 at 6:50 PM
    #109
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Pretty impressive you got it up that high on the ramp! Once you get the lift on you should have a nice flex
    With the terminal I just had to had mine replaced as well and I had a go with plasti dipping my badges and ended up just giving up hahaha
  10. Apr 14, 2014 at 6:55 PM
    #110
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Bigger piping will take away your low end torque on the first gens. Toyota was really good about getting a great flowing stock exhaust
  11. Apr 15, 2014 at 6:59 PM
    #111
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I just don't belief all this talk about huge losses. I'm keeping the stock manifold and everything before the muffler. Muffler back isn't going to change that much.
  12. Apr 15, 2014 at 7:38 PM
    #112
    smmarine
    Melbourne FL
    The 3.4 only puts out 190 hp. 2 1/4" pipe is perfect for that. It'll loose some low end but gain some high. Unless it's supercharged haha
  13. Apr 27, 2014 at 8:20 PM
    #113
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Almost 3 weeks after purchase of my parts from Toytec and no word of them shipping, so I'm assuming my leaves are still on backorder... Sad day.
    Good news is I'll probably have the money for the new wheels by then, so hopefully I can pick up some tires on the cheap to wrap the wheels with so I can jump straight to 33s with the lift.
  14. Apr 28, 2014 at 5:39 AM
    #114
    smmarine
    Melbourne FL
    Did you order dakars?
  15. Apr 28, 2014 at 5:55 AM
    #115
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Yes sir.
  16. Apr 28, 2014 at 6:16 AM
    #116
    smmarine
    Melbourne FL
    I was told by wheelers they're supposed to be in stock on the 28th. So today haha
  17. Apr 28, 2014 at 7:09 AM
    #117
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Hell yes! Hopefully you're right. Being as I'm home in a week and a half. I don't want to wait too long!
  18. Apr 28, 2014 at 8:49 AM
    #118
    smmarine
    Melbourne FL
    Yeah I just double checked my email to wheelers and it said they're back ordered till about 4/28. So hopefully today, if not very soon
  19. May 1, 2014 at 4:10 PM
    #119
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    The next event took place in my truck, so I guess it's appropriate.
    I'll just copy-paste my Facebook status for this.
    "I get out to my truck this morning at 6:30 to go to work. I decide to look at my bike (which I left in the bed overnight) and I notice something odd. Someone had taken a $70 Harley Davidson bike lock and locked both of my wheels together, making it impossible to ride. I look high and low and can't find any keys. I'm screwed right? Nope. I drive to work and get some bolt cutters from the office, grab my dremel from my toolbox and get to cutting. 10 minutes later and one destroyed bike lock and my bike is free. Screw whoever did this."
    Turns out it was some buddies of mine from the Motorsports club here at JMU and it was one of their bike locks and they thought "Taylor doesn't have anything to cut this with." They were wrong.
  20. May 1, 2014 at 4:30 PM
    #120
    smmarine
    Melbourne FL
    Haha, pranks. We used to do so many of those. One day I came outside and somebody had ceran wrapped my truck in the driveway haha. Proved them wrong. So did you get your lift yet?
