Taylor's Taco
Discussion in '1st Gen. Builds (1995-2004)' started by Taylor, Dec 27, 2013.
  1. May 12, 2014 at 9:03 AM
    #161
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    my comp won't load the pics lol ^ too big o_O
  2. May 12, 2014 at 9:09 AM
    #162
    Taylor
    Taylor [OP] Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Should be better now.
  3. May 12, 2014 at 1:32 PM
    #163
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    So, my airbox was getting water in it after pushing hard through deep water, so I put some more silicone on my deckplate.
    I also had found that the PVC hose I had used for the diff breather extension had a huge hole in it. I bought some more flexible 1/4" fuel line to replace it. Ended up shearing every bolt on the bezel around my fuel filler cap in the process. Oh well. Stupid Pennsylvanian trucks.
    Then, we decided to see what the flex was like. Didn't drive it far, just around the back of my house. MUCH improved.
    Before:
    After:
    Not even full stuff. Not sure what'll limit me, shock length or fender well room.
    This is why I cut the exhaust before it bent out. It would never have cleared the leaves at full droop.
    CV angles look good. I don't think I'll be installing my diff drop for now.
    Front suspension up-travel is decreased a lot, but I'll have to live with it for now. Not a big deal.
  4. May 12, 2014 at 1:42 PM
    #164
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Take those shock boots off the rears
  5. May 12, 2014 at 1:45 PM
    #165
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Those eibach coils and setting the 5100 to .85" should get that up travel back! :spy:
  6. May 12, 2014 at 1:54 PM
    #166
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I'm undecided on the boots.
    Also, forget to say that I did change my gear oil. Didn't look like there was much water in it, if any. Looked okay, but not amazing for only a couple thousand miles on it. A little metal on the magnet.
  7. May 12, 2014 at 1:57 PM
    #167
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    If you are gonna be doing a lot of off-roading id take the boots off, they will hold dirt and grime which will collect on the shock rod and cause premature wear.
  8. May 12, 2014 at 2:03 PM
    #168
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I was wondering what to do for coils to keep good up travel. Someone said I could get longer OME coils and just set the 5100s lower
  9. May 12, 2014 at 2:29 PM
    #169
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Yeah, longer coils and a lower setting.
    And Brandon, I guess you're right. I don't feel like taking the bottom off, so I guess I"ll cut them off.
  10. May 13, 2014 at 9:07 AM
    #170
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    I agree^^^^^
  11. May 13, 2014 at 9:52 AM
    #171
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Should I just cut them? Actually, it wouldn't be too much work to just take the shocks off a t the bottom, would it?
  12. May 13, 2014 at 9:59 AM
    #172
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Just cut em off. It's really hard to get the boot off without cutting. Plus you will never need it so no point in tryin to save em.
  13. May 13, 2014 at 10:46 AM
    #173
    smmarine
    Melbourne FL
    I thought the whole point of the shock boot was to keep out dirt and grime? Is it really just to look cool haha?
  14. May 13, 2014 at 11:00 AM
    #174
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I guess it works well for people that don't wheel hard.
  15. May 13, 2014 at 12:47 PM
    #175
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Touched up the bottoms of my sliders.
    It'll just get scraped off again next time I wheel, but oh well.
    Cut the boots off of my rear shocks
    Removed some stickers :D
    and took off my front driver mudflap, since I'm missing the one on the passenger side.
    The rake is really steep. Let's see if it'll settle down.
  16. May 14, 2014 at 6:25 PM
    #176
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Got an e-mail from WheelersOffroad saying that my shackles are out of stock until at least next week, then they have to ship them.
    I decided I'm not driving my mom's truck any longer so I found another nut, and took a HUGE 3/4th drive ratchet and all of my strength to crossthread that bitch all the way until it was flush. Nothing in the world will get that to come loose. I'll worry about getting it off later. I'm just more concerned about getting this aligned and driving it.
  17. May 14, 2014 at 6:28 PM
    #177
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Lol, what I would do!
  18. May 14, 2014 at 7:39 PM
    #178
    smmarine
    Melbourne FL
    Did you drop the front coils? Rake wasn't that steep before
  19. May 14, 2014 at 7:44 PM
    #179
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    I know those stock coils didn't take long to settle! Wore out!
  20. May 14, 2014 at 7:50 PM
    #180
    smmarine
    Melbourne FL
    Hell yeah they did. Time for some new ones haha. Eventually I'm gonna be ordering everything you have. Once I get another job
