TB Clean + mpg drop
Discussion in '1st Gen. Tacomas (1995-2004)' started by LifeIsGood169, Mar 6, 2012.
  1. Mar 6, 2012 at 3:33 PM
    LifeIsGood169
    LifeIsGood169 [OP] Well-Known Member
    Greg
    Philadelphia
    03 Tacoma XtraCab 2.7L 5spd
    Chime Mod Kenwood Headunit Greased all Zerks, locks, and bushings Reverse Flood Lights Extang Cover Weather stripped tailgate Burner Fog Lights Toggle Switches in Dash
    I took off my throttle body and cleaned it along with the MAFS and the intake manifold at 121k miles. Looked real bad, but now it is shiny. I tried to get all the gunk on the rag, but some of the carbon on the intake manifold obviously went through the engine. I started and ran the truck for 30 minutes (driving). It seemed to make white smoke for about 10-15 minutes. The next tank of gas was great. I got 25mpg city... which i've never even got on the highway before. I was so excited, until the last 2 days.
    1-2 gas tanks later I'm getting 15mpg city (110miles on 7.5 gallons). My thought is I either plugged the pre-cat O2 sensor or the cat itself or the MAFS went bad (doubt this), or I somehow hurt the piston heads/rings (but I don't feel a power loss). The truck also idles at 600-650rpms instead of 700-750 rpms. There is no check engine light.
    Tests? Thoughts? Help?
    I'm considering:
    beating my head against a wall pulling out a rusty O2 sensor for cleaning/replacement
    chopping off the exhaust before the cat & replacing with new O2/resonator/muffler & no cat (I have an emissions test from October & I hope to move to a part of Texas in the summer where emissions testing isn't required)
    living with it
    going on a long drive (leaving the truck burning in 2nd gear)
  2. Mar 6, 2012 at 3:49 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    SAS, dents, & scratches
    Bump,
    I would check the maf but I don't have a clue
    Good Luck!
  3. Mar 6, 2012 at 3:56 PM
    LifeIsGood169
    Greg
    Philadelphia
    Yah I'm really betting it is the O2 or the CAT. I just don't understand how a dirty O2 after the engine would lead to a "rich" setting. Because logically when something is dirty it makes sense it reads less O2 in the exhaust than O2 actually present equaling a lean mixture. But I guess somehow the deposits could increase sensor voltage and give a false O2 high.
    Also... maybe my short city driving hasn't been long enough to heat up the O2 and give a CEL. But then idk why the O2 readings would even matter.
  4. Mar 6, 2012 at 4:03 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Are you throwing a CEL? If not everything mentioned here seems completely normal to me...
    Make sure you fully attached your MAF connector. Running a straight pipe with no cat/resonator? Could be affecting your back-pressure.
  5. Mar 6, 2012 at 4:06 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    PreRunner SR5 TRD Sport
    Bull bar, wet suit seat covers, Accessory meter repair, Fog Lights with stick on, console lock.
    fouled plugs?
  6. Mar 6, 2012 at 4:36 PM
    LifeIsGood169
    Greg
    Philadelphia
    Should I do anything besides take them out and spray them with cleaner? Like should I turn the car on an run a little bit of TB Cleaner through the engine to make sure I got everything? Because last time I just did it with the car off.
  7. Mar 6, 2012 at 5:05 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    well now cleaning the spark plugs these days esp. with spray cleaner is new to me.. now back when i was 16 and you had to tune a car every 12,000 miles my grandfather had a plug cleaner he got at sears. it sand blasted them. not up on all the info on the 4 banger, but i assume you should replace them with the standard toyota plug (nothing fancy) evey 30,000 miles or so. in the old days they would foul quick, now they just wear out..
    the O2s sensor can be strange... i think u have 2 also, but the one near the motor does most of the "sensing" the other is a back up, and when they start to go your engine performance can slip till you get the CEL and have you checked your PVC valve?
  8. Mar 6, 2012 at 7:54 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    If you have 2 O2 sensors on a single exhaust manifold (4 banger not a V engine) then the first determines the correct AFR and the second controls the CEL for the Catalytic converter being bad. no "backup" sensors
  9. Mar 7, 2012 at 11:58 AM
    LifeIsGood169
    Greg
    Philadelphia
    I haven't check the pvc valve because idk where it is lol... I know there are tons of pictures that show it, but I still don't see it on my truck. It's like the one thing I'm not familiar with.
    Also, my plugs only have 5k miles on them so cleaning & brushing might work. I haven't looked at them yet though.
    So everyone here agrees the first O2 sensor before the cat won't throw a CEL?
  10. Mar 7, 2012 at 12:06 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    That one can throw a CEL if readings are out of normal, but will not throw a CAT code
  11. Mar 7, 2012 at 1:06 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    dont know if i missed it but what kind of plugs did you use?
  12. Mar 7, 2012 at 7:40 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
  13. Mar 7, 2012 at 8:37 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
