TBS 0045-23
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Obxdrew, Sep 16, 2023.
  1. Sep 16, 2023 at 2:47 PM
    Obxdrew
    Obxdrew [OP] Member
    Drew
    2020 Tacoma Off Road 6sp MT
    None yet
    Looking for the actual link to this TSB
    "Whine Noise From Rear Of Vehicle" 2019 - 2023 Toyota Tacoma Double Cab
    TSB-0045-23
    Hoping anyone can help.
    Thanks
  2. Sep 16, 2023 at 3:08 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  3. Sep 16, 2023 at 3:09 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    I can get it Monday for you at my shop. We have ALLDATa. I seen that tsb they finally included the 19-23 models to fix that whining noise.
    Obxdrew[QUOTED][OP] likes this.
  4. Sep 16, 2023 at 3:11 PM
    Obxdrew
    Obxdrew [OP] Member
    Drew
    None yet
    Awesome all I can find is similar to the link the guy above posted. I'm having a noise from the rear end like this describes but don't know if this is actually the problem.
    Thank you
    Gfenza89[QUOTED] likes this.
  5. Sep 16, 2023 at 3:17 PM
    Gfenza89
    Is it a whining noise around 50mph? If it is then true bulletin will resolve the issue. They put sound padding in the back of your c pillars . And the rear cab mounts get a dynamic damping Cup installed onto them. Although I don’t believe the bulletin applies to Trd off-road models.
  6. Sep 16, 2023 at 3:40 PM
    Obxdrew
    Obxdrew [OP] Member
    Drew
    None yet
    It's like a constant hum, almost like the noise a cicada makes in the summer. Starts about 25 mph and stays constant at any speed above. Doest change w speed, or what gear I am in. I hear it then I have the clutch in and the engine isn't producing driving rpms. I hear it very pronounced when only the rear window is open, although I can hear it faintly with all the windows closed. It's driving me nuts. My first thought was maybe it's the low pressure fuel pump in the tank, or there is some crud or rust in the rear drums/ parking break is dragging on drum.
    :frusty:
  7. Sep 16, 2023 at 3:41 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    nhtsa.gov . See my signature.
  8. Sep 16, 2023 at 3:42 PM
    Obxdrew
    Obxdrew [OP] Member
    Drew
    None yet
    Checked my vin against that database and says I don't have any open recalls
  9. Sep 16, 2023 at 3:44 PM
    Gfenza89
    Interesting because my 23 sr5 has had a weird noise from the rear from day 1. Starts at around 30mph. I had the rear diff replaced and the tsb. The tsb made it little quieter but didn’t completely fix the issue
  10. Sep 16, 2023 at 3:44 PM
    Gfenza89
    A tsb is not a recall
    tonered likes this.
  11. Sep 16, 2023 at 3:45 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Read what is written there. ;)
    You get to the TSB PDFs from the Recall menu.
  12. Dec 18, 2024 at 8:35 AM
    cajuncb
    cajuncb Member
    2020 Tacoma Sr5
    I have 2022 Tacoma double cab TRD SPORT and get that whining noise. I have appointment with Toyota dealer and I will show them the TSB 0045-23.
    Will post results……
    Gfenza89 likes this.
  13. Dec 18, 2024 at 9:13 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
