TC Dual 2.0 Rear Suspension Package - Tacoma 5 Lug
Discussion in 'Suspension' started by tucsonprerunner, Jan 16, 2011.
  1. Jan 16, 2011 at 6:00 PM
    tucsonprerunner
    tucsonprerunner [OP] Member
    tucson,az
    TRD Sport 4x4
    Do they make this setup for 6 lugs? Anyone running it? Comments/reviews?
    TOTAL CHAOS REAR KIT
    PT#88400
    Complete Package
    MSRP $1703.00
    PT#88440
    Spring Kit - Rear Hangers, Shackles,
    U-bolt Plate, Brake line, Spring bushings
    MSRP $659.00
    PT#88450
    Jounce Mount- Bump Stop Mounts, Lower bump stop strike pad
    MSRP $345.00
    PT#88460
    Shock Hoop Kit**- Dual Shock Hoops, Lower Shock, Grade 8 Hardware
    MSRP $699.00
    **1.5” wheels spacers required to install this kit
    MSRP $125.00
  2. Jan 16, 2011 at 6:42 PM
    DevL
    DevL Well-Known Member
    I was told that is was discontinued and not made for 6 lugs due to structural issues since the hoops are not tied together for stability... in other words it breaks if used as intended. I looked heavily into that as a solution for attaching long travel shocks without losing any use of my bed. I finally said screw it and will just get 2.5" King shocks and Deavers for the rear. I can add air bumps if I want to later on.
  3. Jan 16, 2011 at 6:56 PM
    tucsonprerunner
    tucson,az
    TRD Sport 4x4
    My other option I've been checking out is the Giant Motorsports 64" rear kit.
    Tacoma 2005-2008 64" Long Travel Leaf Spring Kit
    Capable of up to 21" of Travel!
    Kit Includes:
    Exclusive 64" triple wrapped race spring
    Front and rear mounting brackets
    Shackles
    Protective ubolt bash plates
    Axle spring perch
    9/16" ubolts
    All necessary bushings
    The all new Tacoma 64", 21" travel spring kit is available in a bolt on version that makes your installation even easier.
    Price: $1700
    Available for:
    2005 - 2008 Toyota Tacoma
    Check out our custom bypass shock setup for all long travel spring kits - "Giant Motorsports Link Killer"
    Link Killer 2.5 shocks are available in black anodize.
    $1375 or 3.0" for $2050
    Tacoma Bolt in Bed Cage
    The new Tacoma bolt in bed cage has a space saving design for cargo and comes with tire mount that that is positioned so you can fit a dirt bike.
    Price: $1850
  4. Jan 16, 2011 at 8:13 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
