TC modified front drive axles
Discussion in 'Long Travel Suspension' started by 04LTtacoma, May 1, 2011.
  1. May 1, 2011 at 3:49 PM
    04LTtacoma
    04LTtacoma [OP] Well-Known Member
    Outer Space
    Does anyone have the TC modified axles on their tacoma?
    I had ordered a set from TC and the axles came with some instructions...
    It says that TC will warranty these axles if the axles click after immediately install? I guess after these factory axles have been modified mt TC they can get fractured...
    The instructions also said something about the angle of the joints can't exceed 28 degrees. So does that mean I need to get the adjustable limit strap for these bad boys? Thanks.
    -Zach
  2. May 1, 2011 at 3:52 PM
    04LTtacoma
    Outer Space
  3. May 1, 2011 at 6:44 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    You bumped this 3 minutes after you made it?
    Well Im sure they are not lying if they say they can break but they will warranty it. For the angle it depends exactly where your strapped right now. Our kit says the travel stays at 13" with or without 4wd though. But why did you buy TC if you have a Camburg kit? They should be the same but that makes it hard for Camburg or TC to answer your questions
  4. May 1, 2011 at 8:57 PM
    04LTtacoma
    Outer Space
    I called TC and asked if these would work with the burg kit. They said it will work with the burg kit.. I got these for a few reason. My CV boots keep on tearing and with these TC axles I can run 2.5" of lift up front.
  5. May 2, 2011 at 10:29 AM
    Cr250jumper
    The moon
    50 shades of tan©
  6. May 8, 2011 at 7:48 AM
    04LTtacoma
    Outer Space
    I didn't know Camburg made modified front drive axles for their long travel kit.:confused: How much are the modified axles that burg makes?
  7. May 8, 2011 at 11:39 AM
    Cr250jumper
    The moon
    50 shades of tan©
