TC shock tower gussets
Discussion in 'Long Travel Suspension' started by rondog, May 16, 2011.
  1. May 16, 2011 at 9:01 AM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    I am thinking I'll have time today to finally put these guys on my truck. For people that have done this install, I just pull the UCA bolt out and remove the outer washers right?
  2. May 16, 2011 at 9:03 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Yepper. Take lots of pics. :)
  3. May 16, 2011 at 9:09 AM
    rondog
    Ronnie
    Escondido/San Diego
    For sure..I can do a write up if I take enough. Me and my roommates just cleaned up the garage and we have like 50% more space than before so doing these kinds of things will be a lot easier :D
  4. May 16, 2011 at 9:13 AM
    mjp2
    NJ
    Nice! :)
    Bolt everything up nice and tight (UCA with the gussets), tack the gussets into place, remove the UCA mounting bolt and UCAs, and weld away. You'll melt the bushings if you weld with the UCAs in place.
    Might be worth it to pull the metal sleeves from inside the bushings and bolt just those in place while you're welding. It'll make sure things stay lined up and don't warp out of position from the heat.
  5. May 16, 2011 at 9:17 AM
    rondog
    Ronnie
    Escondido/San Diego
    good call, I wouldn't of thought of melting the bushings..hey how do you like your giant rear? Im going on 4 weeks waiting for mine plus kings
  6. May 16, 2011 at 9:17 AM
    rondog
    Ronnie
    Escondido/San Diego
    *** giant rear lt kit :p
  7. May 16, 2011 at 9:19 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  8. May 16, 2011 at 9:58 AM
    mjp2
    NJ
    LOL! :laugh:
    Honestly, I'm torn at the moment. I got an early version and my truck's extra heavy in the rear so it's sagged quite a bit. Deaver hasn't had any luck identifying the leaf packs I have (I've had to replace 4 individual leafs over the years and each time it was a custom measurement jobbie) and I get some frame rubbing:
    The components are incredibly stout but obviously I've had some issues. I'm weighing my options and will probably end up making a hybrid rear setup using my existing Giant front hanger, DMZ rear hanger and shackle, and All Pro baja leaf packs.
    I'm not 100% set on what I'll do but this is the direction I'm leaning for now.
  9. May 16, 2011 at 10:04 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ are you still gonna run inverted shackles? My rear shackles rub a lil bit on the frame during articulation but only when turning because the bushings are soft and have some play. I may get harder bushings but I hear they are loud.
  10. May 16, 2011 at 10:36 AM
    mjp2
    NJ
    I prefer the inverted shackle design but the rubbing is obviously a concern. DMZ's rear kit either uses a long hanger or a short shackle in the rear, as it appears that the shackle does not come even with the frame at any point. At least, what's what I could tell from pictures I've been able to find online.
    What's your rear setup these days? Point me to pics if you can because I'm too lazy to browse your build thread. :eek:
  11. May 16, 2011 at 10:38 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Baja 50T pack with Engage 12" shackles:
  12. May 16, 2011 at 10:42 AM
    mjp2
    NJ
    Wow that's actually really nice. Got any pics of how that rear shackle attaches to the frame?
    Depending on how that thing looks, Hassim might be getting a call from me in the next month. :)
  13. May 16, 2011 at 10:45 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    I'll get some pics of the shackle mounts when I get home. Hass has 12" and 13" shackles you can choose from, they are just under $300 IIRC when he listed them on last year's black Friday sale. I was pretty surprised, I watched him build my rear end in 2 days lol
  14. May 16, 2011 at 10:48 AM
    mjp2
    NJ
  15. May 16, 2011 at 10:55 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    heres one off Engage's facebook:
  16. May 16, 2011 at 11:07 AM
    mjp2
    NJ
    This could work. It'll be nice to find an inexpensive solution for my truck...for a change. :)
  17. May 16, 2011 at 11:40 PM
    rondog
    Ronnie
    Escondido/San Diego
    Got one side finished tonight...here is them right before I put the arm back on. I took plenty of pics. I'll make a write up tomorrow.
  18. May 17, 2011 at 12:07 AM
    StatutoryAPE
    StatutoryAPE Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    that is the nicest rear lt setup ive seen on tw. almost all bedspace still available! i wonder if they have done that same style on a 1st gen.
  19. May 17, 2011 at 6:27 AM
    mjp2
    NJ
    Tough to manage that with the 1st gen trucks because the shocks are mounted inside the frame rails.
  20. May 17, 2011 at 6:48 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    yup. you can't mount the shocks right behind the cab because the stock gas tank is in the way. if you run a tundra axle you can mount the shocks outside the frame rails and right behind the cab keeping most of the bedspace, like this guy
    http://www.ttora.com/forum/showpost.php?p=2157571&postcount=19
