TC Torque Spec
Discussion in 'Long Travel Suspension' started by jtlachac08, Dec 2, 2011.
  1. Dec 2, 2011 at 4:01 PM
    jtlachac08
    jtlachac08 [OP] Well-Known Member
    Jeremy
    Phoenix, Az
    Any 2nd Gens running TC LT get heavy squeaking coming from their arms?
    What do you have the upper arms torqued too? I'm wondering if mine are too tight and smashing the bushing over excessively, I've greased the hell out of the zerks plenty of times.
    Same with the lowers, what torque on the ecentrics? Obviously nothing crazy, but is everyone else just running stock spec torque? Or good n tight....
  2. Dec 2, 2011 at 4:08 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    im pretty sure they just squeak naturally.... dont know though! good luck
  3. Dec 2, 2011 at 4:13 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    Im talking like daily driving. Speed bump comes up and EEE RRR EEE RRR, drives me nuts. I notice its not as bad when its cold out
  4. Dec 2, 2011 at 4:27 PM
    Marnes2986
    Marnes2986 Well-Known Member
    Mark
    Anaheim-Corona, Ca
    mine were bad before...been DD my TC kit for the last 5 years...you just gotta get used to wierd sounds lol
    Remember... Race truck parts make race truck noises...
    The usual culprit are my LCAs.....did you put some grease on the uniballs. There are various recommendations out there. I use, white lithium grease. Spray it right on top, hit a few dips or speed bumps, then take a rag and wipe off the excess so it will not collect dirt (which will ruin the inner teflon lining)
  5. Dec 2, 2011 at 4:44 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    i use 90ftlbs for the top uca bolt and 80 ftlbs for the lca bolts. loosen up the bolts grease the bushings and re-torque everything . usually if that does not stop the squeaking it means you need new bushings.
    you can over-torque the bolt but it wont compress the bushing any further , the inner sleeve prevents overcompression.
