TC UCA help neeeded
Discussion in 'Suspension' started by Ese Loco, May 24, 2011.
  1. May 24, 2011 at 7:04 PM
    Ese Loco
    Ese Loco [OP] Taco Man Sam
    Vero Beach, FL / Tampa, FL
    2009 DC TRD Off-Road 4x4 V6 6-speed
    Legal Florida Tint all-around, 1.5" add-a-leaf, bilstein 5100 rear shocks, Light Racing Coilovers, Removed secondary air filter, K&N airfilter, Amsoil 100% synthetic motor oil, Amsoil synthetic severe gear in rear differential, Differential breather mod, Painted rims and logo's black, amsoil oil filter
    Hey,
    So here's my situation, i went to lubricate my Total Chaos UCA's because the Polybushings had gotten pretty squeaky. Everything went smoothly besides the face that it felt like i couldnt grease the back zerk on the drivers side UCA.
    As i tried to force grease in, it would instead squeeze out of the few leaky spots in the gun and i never saw it squeeze out from anywhere on the UCA as i had with the other Zerks.
    Thanks for any help!!
  2. May 24, 2011 at 7:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did you rub grease all over the bushings before installing them on the UCA?
  3. May 25, 2011 at 12:12 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    It is recommended to loosen the Control arm bolt before greasing. This will allow the grease to enter the bushing easier, and also will prevent the bushings from being pushed out due to pressure. Make sure to torque the bolt back after you are done.
