TC UCA Install
Discussion in 'Suspension' started by Brunes, Jun 26, 2009.
  1. Jun 26, 2009 at 10:35 AM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    So here I am....My truck is all apart...I'm trying to do the front end install of my lift. TC UCAs and a OME shock/spring.
    For those of you who have put in TC's....Which way did you bend the metal to get the bolt out and back in....and How do i separate the stock UCA from the spindle??
  2. Jun 26, 2009 at 10:53 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    pull the inner fender towards you.
    I used a mallet to separate... took a little bit but it worked.
  3. Jun 26, 2009 at 10:57 AM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    I'm lucky- They have a pulley puller here...so i popped it with that....but I'm still hitting the insid eof the fender well with the bolt....Guess I'll keep trying!!
  4. Jun 26, 2009 at 12:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    PM me if you need my number. :)
  5. Jun 26, 2009 at 1:18 PM
    BUZZ5
    BUZZ5 Well-Known Member
    S.Carolina
    07 Prerunner DC TRD Sport
    Many
    I used a big cresent wrench & then a bfh to bend mine in & back afterward.
  6. Jun 26, 2009 at 7:05 PM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    Used a set of vice grips to bend the sheet metal out- and back.
    A small pulley puller worked great to separate the steering knuckles and the tie rod ends.
    Got it all put together....Gotta re-check torques tmrw and install the rear shocks....i'll be money after that. Driving home wasn't bad either...Didn't hera any new sounds or feel any new shakes or whatever.
    Thanks for the assist guys!!
