TC UCA owners or anybody with a "lift," how is your alignment? Mine's being a b****
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LeadFootCaliKid, Feb 25, 2010.
  1. Feb 25, 2010 at 9:38 AM
    LeadFootCaliKid
    LeadFootCaliKid [OP] It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    Here is my problem, my alignment sucks.
    1. My caster it too + and my camber is way too +. She wanders on the freeway and you can visually see front he front of the truck that my tires lean out at the top.
    2. Every time I go to allign my truck, I end up bending the tabs that the lower control arm cam-bolts are supposed to rotate within. This only happens on the forward LCA bolt. I've done my alignment myself many times and recently resorted to taking it to a shop but they flattened those tabs worse than I do. I've been told that it's caused by "the lift" but I the TC UCA's are made to help your alignment. So I need some help.
    So here are my questions:
    How is your allignment? Do you have any problems with it? Has anybody else encountered the LCA tab bending issue? How did you solve it? Anybody have any ideas how to easily strengthen those tabs? What do I do?
  2. Feb 25, 2010 at 11:54 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    I'll have to dig my old alignment numbers but I remembered I asked the shop to bring the caster up to 3 so that the tire could be more centered. They had no issues with the LCA tabs.
  3. Feb 25, 2010 at 12:44 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
  4. Feb 25, 2010 at 12:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    My alignment is spot on:
    Toe = 0*
    Camber 0*
    Caster 2.8*
  5. Feb 25, 2010 at 12:48 PM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    Had mine aligned twice with TCs, I don't do the shit myself because of the above mentioned problems. All but one of my measurements are within spec.
  6. Feb 25, 2010 at 1:00 PM
    PreRunner
    PreRunner Well-Known Member
    what kind of numbers are you guys looking for? getting lifted monday, the whole shabang with camburg 1.25's. didn't know what numbers to look for.
  7. Feb 25, 2010 at 1:01 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    My alignment is good as well
  8. Feb 25, 2010 at 1:05 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
  9. Feb 25, 2010 at 1:05 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Bingo :D
  10. Feb 25, 2010 at 1:54 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Well thats definitely not news I wanted to hear. I hope nothing is bent.
