TC UCA Problems??
Discussion in 'Suspension' started by testedone, Jun 2, 2010.
  1. Jun 2, 2010 at 7:39 AM
    testedone
    testedone [OP] Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    I have had the TC UCA's on my truck for about 5K and just noticed the other day what is in the picture below, the front rubber bushing seems to be squeezing out..anyone seen this or have an idea if it is a problem or if it is ok?
    Passenger Side bulge circled
    Passenger Side Closeup
    This is the driver side which is normal looking
  2. Jun 2, 2010 at 9:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That is either over greased and too tight or too loose....I think?? You need to get that seated right and then get that bolt torqued back down right and see if it sets right.
  3. Jun 2, 2010 at 9:38 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    loosen it up, take the bolt out and get all the grease out. then reinstall grease without tightening (little bit) then tighten after you grease
  4. Jun 2, 2010 at 9:39 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    x2
    too tight!!
    the only problem i have with mine is the ball joint is rusting... less than a year old.
  5. Jun 2, 2010 at 9:41 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    fixed :cool:
  6. Jun 2, 2010 at 9:55 AM
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    haha, ok. i had the same deal with mine after i took them off and reinstalled... had them too tight. case to case i guess...
  7. Jun 2, 2010 at 10:19 AM
    testedone
    Rick
    U.S.A.
    to tight? They are both torqued to the same spec on both sides only one side is doing this, I can believe the over greased though..So taking it out and then putting it back in (after cleaning the grease should do the trick? No need to replace the bushing?
  8. Jun 2, 2010 at 10:22 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Just make sure the bushing settles back in correctly. If it's permanently deformed you are going to have to get a replacement.
  9. Jun 2, 2010 at 10:25 AM
    testedone
    Rick
    U.S.A.
    great, I have a 900 mile trip tomorrow morning..
  10. Jun 2, 2010 at 11:11 AM
    testedone
    Rick
    U.S.A.
    Is there a torque spec on this someone might have handy i can't find it...
  11. Jun 2, 2010 at 11:14 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Same kinda thing happened to me and it was just over-greased. I took a paper clip and pushed in the bushing where the the zerk fitting is and the extra grease flowed right out. Took it for a drive after and the bulge was gone.;)
  12. Jun 2, 2010 at 11:15 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    yep thats a case of too much grease.
    My uni-balls are rusting too. :eek:
  13. Jun 2, 2010 at 11:17 AM
    testedone
    Rick
    U.S.A.
    yeah I smear some grease on the upper and lower portions of the uni-ball also...
  14. Jun 2, 2010 at 11:18 AM
    testedone
    Rick
    U.S.A.
    I was just about to jack the truck up..when I saw this post...I will try that first!
  15. Jun 2, 2010 at 11:21 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    May want to get some teflon lube for them.
  16. Jun 2, 2010 at 11:24 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah my passenger side uniball squeaked a little bit so I sprayed some dry teflon lube and it was good to go.;)
  17. Jun 2, 2010 at 11:30 AM
    Dark Knight
    Jeff
    NC/SC
    true... I guess I just dont like the idea of that attracting even more dirt.
  18. Jun 2, 2010 at 11:32 AM
    testedone
    Rick
    U.S.A.
    You sir are officialy on my Christmas card list and birthday list!! The paper clip did the trick..grease jetted out, it was way overfilled and the bushing just sank back in, I am going to ride it around and then do it again just to make sure...
    You saved me a ton of work before my trip!
    Thanks much!
  19. Jun 2, 2010 at 11:39 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey no problem. Thats what we're here for bud!!;) Glad it worked out.
  20. Jun 2, 2010 at 11:51 AM
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Youg ot a link? How often should we apply the lube?
