Teach me how to mall crawl yall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmast, Dec 30, 2012.
Thread Status:
Not open for further replies.
  1. Dec 30, 2012 at 8:32 AM
    jmast
    jmast [OP] Is it June yet
    O.I.C.
    2011 DCLB TRD SPORT
    Taz mudflaps
    Never heard of such a term until I joined here
    I am sure this is not a reference to senior citizens getting excersise
    What do I need to mall crawl?
  2. Dec 30, 2012 at 8:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Mall Crawling is a lost art. First, You need to get your truck really clean. Then, head to a local Mall, strip mall, or shopping center. Prop one tire on a curb, and BOOM! You crawled a mall! Extra points if you park a tire on a weed.
  3. Dec 30, 2012 at 8:41 AM
    Slikk
    Slikk Well-Known Member
    Kevin
    Nashville, TN
    2013 4X4 Off Road
    ^^ lol.. are you serious?
  4. Dec 30, 2012 at 8:42 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Extra bonus points are also given if your truck is lifted really high with huge chrome rims and low profile mud tires. The "look" is everything. ;)
  5. Dec 30, 2012 at 8:43 AM
    acdronin
    acdronin Well-Known Member
    Does he have to wear his cap askew or backwards?
    MadDaddy likes this.
  6. Dec 30, 2012 at 8:44 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Not just clean, you need to add as much shit you can afford to be an awesome off road truck, then only take it back n forth to the mall. Using different parts of the parking lot also give extra points.
  7. Dec 30, 2012 at 8:46 AM
    Slikk
    Kevin
    Nashville, TN
    2013 4X4 Off Road
    Sorry i had to consult Professor Google.
  8. Dec 30, 2012 at 8:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think that just increases the catagory of the Crawl. For example, a stock truck can only get to a cat. 1 mall crawl. Where as mine, when propperly washed, can get to a level 3. 5 is the most, but mostly only Hummers (H2's), and other rediculasly lifted vehicles with 28" wheels can achive the level 5 crawl.
  9. Dec 30, 2012 at 8:48 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Good point, and noted.
  10. Dec 30, 2012 at 8:51 AM
    Ben83
    Ben83 I am faster than 80% of all snakes.
    Ben
    Central Virginia
    12 MGM TRD Sport DCSB
    Extang Solid Fold Seat Covers Trimmed the mudflaps. Husky Liners
    These are the trucks that come to mind when I think of mall crawlers:
  11. Dec 30, 2012 at 8:51 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    As stated above, for maximum mall crawlage your truck must be outfitted with an extensive array of off road parts. Like a massive lift, preferably a body lift, and big off road tires, and stickers and chrome. This type of rig must never see dirt, so that it can stay super clean for the mall parking lot. The Comes the real fun! Go to the mall and park like an ass hat! Putting one tire up on a curb is a time honored way of doig this. and since it is winter, tis the season, another great way to mall crawl is to drive your truck up into the huge piles of snow that get built up from plowing the parking lot. Bam! You just mall crawled.!
  12. Dec 30, 2012 at 8:52 AM
    arkansasman5
    arkansasman5 Well-Known Member
    James
    Fort Bragg, NC
    I might try this.
  13. Dec 30, 2012 at 8:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This one shows good effort, and with the 6" DB lift, you would think it would score high. However, note the dirt on the sides. This is an Automatic DQ from the Mall Crawl. TRUCK MUST BE CLEAN!
  14. Dec 30, 2012 at 8:54 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    It is similar to what in the old days ways the Burger Run. You would get your supped up, shined up vehicle, head over to the local burger joint and drive slowly around showing off your ride. And ride around, and ride around, and ride around..... :turtleride:
    Back in the muscle car days, with the monster motors, radical cams, and no smog crap, even going slow sounded mean. Gas was cheap and Sunoco 260 could fuel the beasts. :cool:
  15. Dec 30, 2012 at 8:54 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Exactly Chris! Valid point! This specimen here below is a prime example of a level 5 mall crawler. He doesent even need to park on any curbs to get maximum mall crawl status.
  16. Dec 30, 2012 at 8:56 AM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    To be considered a true mall-crawler, is it necessary to have large, vision-blocking stickers advertising the latest energy drink or southern california surf company in your rear window??
  17. Dec 30, 2012 at 8:57 AM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    Pavement princess lol
  18. Dec 30, 2012 at 8:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. You can reach the Cat 5 mall crawl without them. However, the ones with the stickers generally like to think their Mall Crawl rig is sponsered by whoever sent them the stickers. Being as its not yet a sanctioned event, one must pretend.
  19. Dec 30, 2012 at 8:59 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Buy a prerunner
  20. Dec 30, 2012 at 9:00 AM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    That guy must have a 2 incher. :rolleyes:
Thread Status:
