#teamstealth gallery
Discussion in 'Stealth Custom Series' started by SCSPerformance, Mar 2, 2016.
  1. Feb 9, 2017 at 8:21 AM
    #301
    ChadsPride
    Sponsored by TacomaWorld.com
    Does anybody have a link to buy Black Spline Lug Nuts to be used with SCS F5's
    Thank you all​
  2. Feb 9, 2017 at 8:32 AM
    #302
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
  3. Feb 9, 2017 at 8:33 AM
    #303
    ChadsPride
    Thanks a bunch!!! Are these what you run?
  4. Feb 9, 2017 at 8:41 AM
    #304
    ChadsPride
    Whats the difference in those ^^^^^^^
    and these
  5. Feb 9, 2017 at 8:59 AM
    #305
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I run the same design, but ProComp brand (since I needed them fast, I bought local).
    The difference between the two is the ET or Extended Thread portion of the lug nut (those referenced in my link have the ET, those in your link don't).
    You can see the extended shank below the acorn bit, this extra bit of threaded shank helps secure aftermarket wheels to the wheel studs better. The reason this is a thing is that the increase backspacing of the aftermarket wheel pushes the lug nut outward on the studs leaving the wheel being held on by fewer threads. The longer ET nuts compensate for this and recovers some use of more threads on the stud, aka results in more secure wheel with less chance of lug nuts backing off.
    Greco, Beef Nachos, bski22 and 2 others like this.
  6. Feb 9, 2017 at 9:00 AM
    #306
    ChadsPride
    Wow!!! I really appreciate the response. Thank you!!!
    Pistol Pete likes this.
  7. Feb 9, 2017 at 9:02 AM
    #307
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Absolutely, all just some knowledge I recently learned when buying my wheels from Vin, glad to share.
    ChadsPride likes this.
  8. Feb 9, 2017 at 9:26 AM
    #308
    ChadsPride
    :cheers:
  9. Feb 10, 2017 at 4:03 PM
    #309
    RC84
    RC84 Well-Known Member
    3G Double Cab TRD OR
    SCS F5 - 17x8.5 Matte Gunmetal Cooper ST Maxx - 255.80.17
    Just got the new wheels and tires installed.
    Scs F5 matte gunmetal finish. 17x8.5"
    Cooper St maxx 255-80-17 tires
    Factory suspension.
    20170210_174330.jpg 20170210_174709.jpg 20170210_174348.jpg 20170210_174423.jpg
  10. Feb 10, 2017 at 5:30 PM
    #310
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Interesting, any rubbing at all with that tire size at factory height?
  11. Feb 10, 2017 at 5:59 PM
    #311
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Vin those don't look any where near the side wall height of 255/80/17... pics close up.. or didn't happen
    And I'm so confused. His profile says quicksand taco?
    ChadsPride and Matmo215 like this.
  12. Feb 10, 2017 at 7:09 PM
    #312
    RC84
    I'm experiencing slight rubbing @ around half turn...clear at full turn.
    I plan on removing the factory flaps tomorrow and alignment with additional positive castor. We will see...
    Eventually I will lift the truck, but not much. Maybe...1 to 1.5 inches.
    Open to any advice or suggestions.
  13. Feb 10, 2017 at 7:20 PM
    #313
    RC84
    Sorry for the confusion bski. The quicksand taco was wrecked and traded in.
    Tires are indeed 255.80.17....ill take a pic in the morning.
    ChadsPride and bski22[QUOTED] like this.
  14. Feb 10, 2017 at 7:35 PM
    #314
    bski22
    Rob
    Toyota
    I was just bustin balls man.truck looks good! had one to many pops this evening
  15. Feb 10, 2017 at 7:47 PM
    #315
    Quakes15
    Quakes15 Well-Known Member
    Peninsula (BAY AREA)
    TRD Sport Toyota Tacoma X DCSB 4WD
    ICON Stage 3/ Stealth 6's/ Nitto Trail Grapplers
    This looks GREAT! I think I have spotted your truck once around Redwood City.
  16. Feb 11, 2017 at 3:38 PM
    #316
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    More pics to come, but for now:
    Stock suspension, no TSB leafs
    265/75R16 BFGoodrich KO2
    Drivers front mudflap rubbing under sharp left turning
  17. Feb 13, 2017 at 6:16 AM
    #317
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Installed my F5's on Saturday. Matte Gun Metal 16-8-16 w/ 3.5 BS. I really like the look of these wheels.
    List:
    1. Lift height: 12" FOX CO's on SAS
    2. Tire size: 285-75-16 General Grabber AT2's
    3. Any rubbing? None
    4. What you had to cut/trim/chop: No cutting to make these wheels/ tires fit.
  18. Feb 13, 2017 at 6:18 AM
    #318
    ChadsPride
    Those look awesome!!!! Such a great looking truck!!!!!!!
  19. Feb 13, 2017 at 6:29 AM
    #319
    Ritchie
    Thanks.
    1st new set of aftermarket wheels I have purchased.
  20. Feb 13, 2017 at 6:30 AM
    #320
    ChadsPride
    My F5's will also be the very first for me too!
