TEC || Ardbeg Fall Run 2020 (Oct 2 - 4)
Discussion in 'Ontario, Canada' started by Norilsk, Aug 16, 2020.
  1. Oct 1, 2020 at 9:05 AM
    #281
    Norilsk
    Norilsk [OP] Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    We usually blast music till 4am with fire.... Chainsaw is fine
  2. Oct 1, 2020 at 9:16 AM
    #282
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    fwiw i am bringing a milwaukee electric chainsaw with lots of battery power anyone can use. probably more than enough cutting power for anyone who isnt Russian.
  3. Oct 1, 2020 at 9:48 AM
    #283
    vonclicas
    vonclicas Well-Known Member
    Filipe
    Lx470
    33” mud tires
    Cool, I will bring my cordless Sawzall with a long blade instead
    Tridet167 and Tech HoFFinaTor like this.
  4. Oct 1, 2020 at 10:04 AM
    #284
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    @Toms2Yotas and 2 on our way!! Beer and herb countdown at T-4 hours and counting
  5. Oct 1, 2020 at 10:15 AM
    #285
    Norilsk
    Eugene
    Take the spot marked on map in first post and thank you! See you tomorrow!
  6. Oct 1, 2020 at 1:48 PM
    #286
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Forecast had nothing but bleak and rain but so far so good
    llamasmurf, 3JOH22A, tgelata and 2 others like this.
  7. Oct 1, 2020 at 1:52 PM
    #287
    vonclicas
    Filipe
    Lx470
    33” mud tires
    Tarps and more Tarps
    Tech HoFFinaTor likes this.
  8. Oct 1, 2020 at 2:06 PM
    #288
    OrangeTaco101
    OrangeTaco101 Well-Known Member
    Devin
    London Ontario
    17 Taco on 35’s
    Won’t be able to make it this time unfortunately anymore. 4WD is not working atm. I’ve fixed the front actuator only to come to find out something is wrong with my transfer case actuator as well ‍♂️. I will definitely be coming to the spring run and others next year and can’t wait.
  9. Oct 1, 2020 at 3:14 PM
    #289
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    I wanted to bring rtt but I'm going to try to sleep in the back of the truck like I've seen others do. Will work tonight till 5am so planning on leaving after noon tomarrow should be there around 3 if all goes well... OrangeTaco101, please keep us informed I'd like to know what the problem is since I just had an experience with my own 4wd problem..
  10. Oct 1, 2020 at 3:27 PM
    #290
    OrangeTaco101
    Devin
    London Ontario
    17 Taco on 35’s
    Will keep you guys informed as well here is a thread that I started if you want to follow as well about my issues and progress. Going to take a look into the transfer case shift actuator this weekend and see if any signs of water or corrosion and if not will most likely take it into Toyota to see if they will fix under power train warranty.
    https://www.tacomaworld.com/threads/4wd-not-working.686415/
    Shveet likes this.
  11. Oct 1, 2020 at 3:44 PM
    #291
    Tech HoFFinaTor
    Tech HoFFinaTor Well-Known Member
    Tyler
    2000 4Runner SR5 5spd
    Eibach/FJ80 Suspension, SkyJacker, Rola Basket, CBI Offroad, Snorkel
    The shift actuators arent uncommon for Toyotas. @OrangeTaco101 You said you had an ADD issue aswell?
    I hope to get there latest 8pm tomorrow. Gonna try and get off work early but gonna head home right after, pick up the cooler and then be on my way.
  12. Oct 1, 2020 at 3:47 PM
    #292
    Norilsk
    Eugene
    I’ll be rolling past 11PM, so better have my dinner ready and fire blasting! ;)
  13. Oct 1, 2020 at 4:01 PM
    #293
    OrangeTaco101
    Devin
    London Ontario
    17 Taco on 35’s
    Yes had the add issue and fixed that and now my front seems to lock but my transfer case is not locking into 4.
  14. Oct 1, 2020 at 4:06 PM
    #294
    Windigo
    Farook
    '14 Acess Cab
    Didn't you also have a abs problem?
    Do you think that has anything to do with it?
    When I had some problems with my 3rd gen ram Cummins I was told to disconnect the battery positive and touch it to ground to reset everything. I did that and the truck started. Don't know if that will apply hear. But maybe you have to disconnect the battery to reset whatever has to be reset....
  15. Oct 1, 2020 at 4:12 PM
    #295
    OrangeTaco101
    Devin
    London Ontario
    17 Taco on 35’s
    Yes I did have a broken abs sensor but replaced that and abs light and that all went off so that issue is fixed. That was due to wheel bearing breaking/falling apart and broke abs sensor. Wheel bearing went as I broke the portion of the cv shaft that goes into the hub. And had to finish the trail with no cv holding the assembly together as I did not have a spare at the time. That was on greens. Here’s a short video I made of greens but still lots more I’ve got to add to the video but have not got around to it.
    https://drive.google.com/file/d/19dacYdfxMHlbeDc7d2DtvT-LMsyYi7ar/view
    llamasmurf and Tech HoFFinaTor like this.
  16. Oct 1, 2020 at 5:03 PM
    #296
    Windigo
    Farook
    '14 Acess Cab
    Great video.
    You can't even get an idea if how awesome greens is without being there. Videos don't do it justice.
    Anyway nice crawling man.
  17. Oct 1, 2020 at 5:04 PM
    #297
    LandoFernano
    LandoFernano Well-Known Member
    Kyle
    Ontario, Burloak
    2020 TRD OR ACLB MT
    TRD skid-plate, Cali raised trail edition rock sliders, Diamondback HD cover, Cali raised bed stiffeners, 265/75/R16 BF KO2’s, extended rear diff breather mod, demon shackle mounts, factor 55 hitch receiver/recovery point,
    There will a raging fire when you get there, that’s for sure, this is what I got so far, might grab a bag or two on the way up just to be safe
    Kyle like big fire :bananadead:
    Maybe also some philly cheese steak pockets if they haven’t been polished off by then:D
  18. Oct 1, 2020 at 5:07 PM
    #298
    Tech HoFFinaTor
    Tyler
    Gotcha. Yea, even if you get somebody to switch the selector while you're under the truck you should be able to hear or feel if the actuator motor is actually doing anything or not. I believe that actuator has a breather on it but I could be wrong about that.
    Btw, for all you 2nd gen owners, want any axles? I have 2 good axles off a 4th gen 4Runner that I can bring up and give to whoever wants them.
  19. Oct 1, 2020 at 5:08 PM
    #299
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    All I seen was Ardbeg! When we doing this?!
  20. Oct 1, 2020 at 5:11 PM
    #300
    Taco-Can
    Taco-Can Well-Known Member
    Glenn
    Port Hope, Ontario, Canada
    2015 TRD Off Road Access Cab
    Sorry guys, unfortunately I have to bail on the weekend. Looks like your all primed and ready to go.
    Enjoy and see some of you at the Ganaraska trail day.
