Tech in North County area, if anybody needs work I'm your guy!
Discussion in 'Southern California' started by Speed Freek, Feb 5, 2012.
  1. Taco me elmo
    Taco me elmo Who needs roads?
    Micah
    San Diego, CA
    2002 5VZ Daily Beater.
    Doug Thorley Headers, Magnoflow 24' muffler, URD short shifter kit, Fox coilovers re-tuned with Total Chaos Upper control arms in front set at 2.5 inch lift, 10 inch Fox rear shocks with resi in back with custom bedcage , Full front and rear Fiberglass, Slotted Tundra rotors with green stuff brake pads, Steel braided brake lines all around, Ultragauge OBDII, Sliders, Front and rear tube bumpers.
    I have the bushings, its the sleeves that no one sells
  2. bradicus8
    bradicus8 Well-Known Member
    Brad
    Buena park, CA
    do you install aftermarket head lights? got some spyders ready to go in my 2006
  3. VolcomTacoma2011
    VolcomTacoma2011 Well-Known Member
    Jeff
    Fairfield, NorCal
    2011 TRD TX|Pro PreRunner DC
    Stock-trading in soon
    I think Jason does everything. And if he doesn't know how to do something, he'll learn how and still do it for you :)
  4. Speed Freek
    Speed Freek [OP] Turbo Meister
    Vista, Ca, Lake Havasu, Az.
    98' 2.4 extra cab w/LS1 Aluminum V8
    ARP Head Studs, Ported Head, MLS Head Gasket, GT3076R Garrett BB Turbo, Synapse Tubular SS Exhaust Manifold, PSI Forward Facing Sheet Metal Intake, Intercooler, 550cc injectors,255lph Fuel Pump, Speed-Trac Traction bars, Heim joint Strut bars, URD Short Shifter, CC Twindisk Clutch, , Haltech Platinum Sport 1000 Standalone ECU, Pre-runner rear springs, V6 rearend with TRD limited-slip Differential New list....LS1 with T56 6-speed trans...simply awesome.
    You are very welcome, thanks for your business, lwt mw know if I can help in the future.
    Thank you.
    Awesome, much appreciated! All my work is through referral..
    Yeah, no problem I am sure I can handle a headlamp install, they arent too difficult.
    We needed the stupid steel sleeves, Micah had the poly bushings, the problem was that the new arms had no bushings or sleeves and to remove the old ones is virtually impossible without damage.
    Yep...
    Thats right! I aint scarred. I am smarter than I look, lol.
  5. 2ski4life7
    2ski4life7 Well-Known Member
    Grant
    San Diego ca
    '12 DCLB 4x4 FTMFW
    Hey can you pm me how much to install bolt on bamf sliders? It requires a couple drill holes if I remember correctly
  6. jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    sub..
  7. RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
  8. Taco me elmo
    Micah
    San Diego, CA
    Honestly welding them on is 1000000X better option.
  9. 2ski4life7
    Grant
    San Diego ca
    '12 DCLB 4x4 FTMFW
    I got the bolt on version. I wanted the option to take them of(Just for resale value). Still debating if I want to keep my truck and modify it or trade it in for a AC SB. Otherwise I would have gotten weldon.
  10. Speed Freek
    Depends on how long it takes but it won't be a lot if it's a bolt on affair, could do it while you wait, they all go on Differently so it's hard to say exactly but will be more than fair and will be done properly.
  11. 2ski4life7
    Grant
    San Diego ca
    '12 DCLB 4x4 FTMFW
    I think there are 2-4 drill holes needed, which I dont want to do because my mark and cuts never match up. Ill see if the other socal guys are having a build day for the boltons if not I may hit you up. Thanks.
  12. shawnphoto
    shawnphoto Well-Known Member
    CALI
    Fully Built '92
    Total Chaos full uniball kit, 3.5 over with spindals and heimed steering swayaway torsion bars All pro long travel rear springs 16" race runner resi shocks fox shocks and reservoirs up front full tube cage in rear hyrdro bump stops rear HID headlights Roof rack with HID liights (5) Hanneman 4in front fenders, flat top rear fenders, hood Grant Steering wheel CB and PA 6 17x8 wheels 285/70/17 BFG MT KM2's Magnaflow exhaust SR5 seats
    Think you could PM me a quote for timing chain replacement on a 92 22re? If i supply the kit and fluids
  13. Speed Freek
    Replied to you PM, thanks!
  14. Taco me elmo
    Micah
    San Diego, CA
    All is well with my money pit.:laughing:
    Had Jason do a full brake overhaul and replace/repair a bad leaking rear axle seal.
    On my way to Jasons house out of the FRIKING blue I lose brake line pressure and cruise through an intersection... thankfully it just turned red and no one was going...
    Turned out to be a bad crush washer seal on a tight line.. he loosened and re tightened both sides lines just in case.
    I swapped my pads and rotors to Hawk LTS pads and Power Slot Cryo treated slotted rotors and he cleaned up and got the rear brakes working proper again, the bad rear axle seal was shitting oil all over the drums so my Ebrake was not working properly.
    My old pads were EBC green stuff and had about 60k on them and were cracked and getting pretty worn down and the old rotors were still good and were powerslot standard slotted rotors so I donated them to Old Man Doug, His were in need of replacement so it all worked out.
    I am one of his more regular customers and get maintenance work done as peace of mind when I can because a small amount for parts and labor now is far better than a failure.
    So far in the past 12 months my truck has needed some very expensive parts replaced because I was not keeping up on them.
    Live and learn, Get a mechanic you trust and have them take 5 minutes on your truck looking for things that need attention you would never think of.
  15. Speed Freek
    Thank you Micah!
  16. ntydog13
    ntydog13 Well-Known Member
    Alex
    Santa Barbara
    86 4x4 long travel pick up
    Lc engineering power pack, total chaos gen 2 caddy kit, 2.5 race runners, deaver f67, total chaos 12in shackles, king 2.5 double bypasses, corbeau baja ss fixed back seats
    Hmm any interest in doing a 5zvfe or 2jz swap into a pickup :drevil:
  17. Speed Freek
    Wouldnt even bother with the V6, they are pretty weak as far as a swap goes, a 2JZ, that would be pretty mean, but also pretty hard on the wallet! Open check? And if its 4x4, sheesh, a few things fighting for the same spot!
    But it would have to be bid at time and material, which means I cannot say how much, mine has an LS1 and a T56 so anything is possible!
    Very, very time consuming is an understatement, did everything myself.
  18. Okeetee
    Okeetee I like the Anaheim Ducks
    Kyle
    Anaheim, CA
    '11 MGM TRD Sport DCSB 4x4
    OME 887 coil springs, Bilstein 5100s (front/rear), Light Racing UCAs, Wheeler's HD 1.5" AAL, 16x8 Konig Countersteer Offroads, Goodyear Duratracs (265/75/16)
  19. Speed Freek
    Right back at ya! :)
  20. VolcomTacoma2011
    Jeff
    Fairfield, NorCal
    Lol we told ya to go with 2.0's, but Noooooooo you had to be a pioneer lol :D
