Tech Stream
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimmywestco, Mar 21, 2023.
  1. Mar 21, 2023 at 9:43 AM
    Jimmywestco
    Jimmywestco [OP] Well-Known Member
    James
    2019 SR AC
    Intermittant wipers, fog lamps wired like factory, remote entry via SE Toyota Dealers kit installed.
    Hi, can anyone tell me where I can purchase or obtain a copy of the Tech Stream software?
    Thank you .
  2. Mar 21, 2023 at 9:47 AM
    Jimmywestco
    James
    2019 SR AC
    Well on second thought and looking at the threads it might not be something I want to tackle.
  3. Mar 21, 2023 at 9:52 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Its not that bad.
    Download, follow the directions make sure you're not connected to the internet. etc
  4. Mar 21, 2023 at 9:53 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Have you looked into Techstream lite?
  5. Mar 21, 2023 at 10:15 AM
    Jimmywestco
    James
    2019 SR AC
    No I'll check it out. Where to find info on it?
  6. Mar 21, 2023 at 10:29 AM
    dentedporsche
    dentedporsche Well-Known Member
    Ron
    Buy a "modified" version and mini-vci (j2534) cable on eBay.
    Install xhorse drivers, register, and select vmi device in techstream ... good to go.
  7. Mar 31, 2023 at 7:09 AM
    Molina67
    Molina67 Well-Known Member
    Ken
    2022 Tacoma SR5
    Got my Techstream yesterday link below worked flawlessly. The only issue is that when I went in to do some customization on the setting not very much to customize on my SR5. I used it quite regularly when I had a Camry XSE and had multiple customized setting but guess the SR5 doesn't have anything to really customize. Really wanted to turn on the lights when the wipers came on in raining situations but when I went it that options was not even available.
    https://www.amazon.com/dp/B09TXLF7GQ?ref=ppx_yo2ov_dt_b_product_details
  8. Mar 31, 2023 at 7:15 AM
    tacos4u
    tacos4u Active Member
    I turned off my seatbelt ding on my 2020 and was able to turn my alarm on is what I needed Techstream for. But its good to have with all the vehicle codes and test I could do.
