Technology mounting bracket
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rockothetaco94, Jul 31, 2019.
  1. Jul 31, 2019 at 12:32 PM
    Rockothetaco94
    Rockothetaco94 [OP] Member
    Gibson
    Northern VA
    2018 TRD OffRoad Crew Cab
    Hey all, I just bought my first Tacoma and I couldn't be more pumped. Its an 03 TRD Offroad extracab. I dont want to do much to the interior but I'm interested in installing a technology mounting plate. Something i could put a phone or tablet ram mount on. I wanted to see if anyone here had any suggestions? Thanks!
    Taco critter and GQ7227 like this.
  2. Jul 31, 2019 at 3:24 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    here was my solution. Simple, cheap, effective (for a phone):
    I just modified a cheap "universal" phone mount and bolted it to the empty switch cover plate on the dash. It still rotates 360 degrees, too.
    I think for your Xtracab, this is where the airbag key is, though...
    I was once considering a tablet mount, but I haven't really found anything that doesn't still flop around quite a bit (at least for off-roading). I considered a custom bracket that screws to the mounts for the double DIN radio, but I just didn't see it necessary to cut up the dash for that.
    For me, the cost/benefit for a tablet just wasn't there. My phone works perfectly well enough.
    Rockothetaco94[OP] and GQ7227 like this.
  3. Jul 31, 2019 at 3:43 PM
    Rockothetaco94
    Gibson
    Northern VA
    That looks like it works great! Thanks, but you're right, That's where the airbag switch is.
    I've just got a simple vent mount right now that wobbles around way too much.
    GQ7227 likes this.
  4. Jul 31, 2019 at 4:53 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    live without technology :bowdown:
    i don't have a good solution other than a gravity free phone!
    ... just joking around lol
  5. Jul 31, 2019 at 4:56 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    or perhaps something along this line of thinking
    not her per se, but the thing she has on her head holding the refreshing beverages, but holding your phone instead!
    dammit she looks like a girl i used to go out underage drinking with afterhours in high school, she was a redhead and they are crazy!
  6. Jul 31, 2019 at 5:00 PM
    jbrandt
    Justin
    It does, it's at a much better height than even a factory nav system (on newer vehicles). It's high enough that I don't have to look down very far, but doesn't obstruct my view like most of the suction cup types that go on top of the dash.
    I've seen some mounts that bolt to the driver side A pillar handle. Those seem pretty cool but probably obstruct your view a little more than I'd like.
  7. Jul 31, 2019 at 5:07 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Rockothetaco94[OP] likes this.
  8. Jul 31, 2019 at 5:11 PM
    Brewster52
    Brewster52 Well-Known Member
    Bree
    2014 DCSB
    I’ve been looking at the tech deck.
    And Rago fabrication has a cool molle panel with”bridge” that is similar to the Teck deck, but only 3rd gen right now.
    I’m thinking I’ll wait for Christmas and hope that Rago has the 2nd gen out by then.
    MrFixit420 likes this.
  9. Jul 31, 2019 at 5:13 PM
    Rockothetaco94
    Gibson
    Northern VA
    Does tech deck make them for the gen 1s? I thought it was only 2s and 3s?
  10. Jul 31, 2019 at 5:15 PM
    jbrandt
    Justin
    There's a thread about the aftermarket "forgetting" about the 1st gens. This would likely be an example of that. I don't think they do. You might be able to modify a 2nd gen one to work, but at that point, you may as well make your own from scratch.
  11. Jul 31, 2019 at 5:25 PM
    Brewster52
    Bree
    2014 DCSB
    Aw shoot my bad, looks like it’s only for the second gen :(
    Right now I just use some magnetic thing sorta like this ...5EACA7E1-3C0C-40CA-9E53-C526BC38717E.jpg
  12. Jul 31, 2019 at 5:45 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Interesting, I tried doing something similar and the weight of my phone broke the switch blank tab off
  13. Jul 31, 2019 at 6:41 PM
    jbrandt
    Justin
    lol, yeah, that hasn't happened yet. If I give it a good yank, it will pop off, but never had it fall off unintentionally.
    This mount is really low profile, it's basically flush mounted to the switch blank. I guess that would be the main disadvantage to this one is that it doesn't tilt up and down. I used to be able to just tilt the phone in the clamp, but then the clamp isn't holding it as tight and it would fall out of the mount. I ended up heating up and bending one of the sides so it curves around my phone better, but now I can't tilt the phone at all. 95% of the time it's not a problem, but sometimes the sun gets right on it and it's hard to see. If I could tilt the mount, even just a few degrees, that'd be nice.
  14. Jul 31, 2019 at 9:05 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
  15. Jul 31, 2019 at 9:07 PM
    Wulf
    rock raisin
  16. Jul 31, 2019 at 9:13 PM
    mtucker
    Escondido, CA.
    03 Prerunner DC
    You have to put that on a cheapskate sliding scale. :) For a "C" shaped piece of plastic it seems expensive, but it has worked great for me. I got tired of messing with vent holders. It is very solid even with the Craigsdock (a bit heavy (made of metal)) and a 6"+ phone on it.
    Wulf[QUOTED] likes this.
  17. Aug 7, 2019 at 5:30 AM
    Vitamin J
    Vitamin J USN Vet
    Oklahoma City
    2014 White DCSB PreRunner Texas Edition 4.0L V6
    Just cosmetic: Window Tint, radio knobs, temp control knobs, Tech-Deck, Tonneau bed cover, tail gate lock, de-chromed all badges inside and out, installed back up camera and custom bedside decals.
    What holder is this? Does the magnet not affect the phone?
  18. Aug 7, 2019 at 6:05 AM
    Brewster52
    Bree
    2014 DCSB
    I’m not sure it has a name lol I just type in Amazon like “magnetic dash ball”
    I’ve mine for like 4 years and no problems with it at all. Phone hasn’t had a problem and the magnet is still holding strong.
  19. Aug 7, 2019 at 6:17 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    For a first gen, you have a few options.
    You can of course install a ram mount that suctions to the windshield, and use either their tablet holder, or build your own. I've done that (building my own tablet holder) and I think it works quite well.
    The RAM mount parts I used were Ram Mount RAM-B-166U-C - Suction Cup Mount with Long Double Socket Arm and Diamond Adapter, and then I made my own tablet holder out of wood. Note that I think a lot of folks would use a RAM-HOL-UN9U to hold the tablet instead, but I think that might mean you need a triple suction cup (RAP-B-365-224-1U) as well.
    You can also put a RAM mount on the A-pillar, and have your phone hang out on the left side (personally, I used that mount for my ham radio face). There's probably not enough room for a tablet there though. For instructions on how to do that, check out Adding a Ram Mount to the #%@#$@! A-pillar.
    RAM mount parts:
    You can also go with a Panavise Custom InDash Mount for Toyota Tacoma '98-04. I've heard that these aren't super stable with their default attachment mechanism, but my guess is that's probably a personal opinion. You can then mount a RAM ball on it.
    478DblSport and 0xDEADBEEF like this.
  20. Aug 7, 2019 at 6:58 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Can you make a blank one without the ball?
