Techron Fuel tank cleaner
Discussion in 'Performance and Tuning' started by xSpyderguyx, May 5, 2010.
  1. May 5, 2010 at 8:19 AM
    xSpyderguyx
    xSpyderguyx [OP] Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    I browsed some online shops last night just to find Techron. It comes in 12 and 20 gallon amounts. But my tank is 16.
    So should I just buy the 12 gallon tank bottle and just put in like 12-13 gallons.
    One more thing (Man i ask TW everything!) Should I use chevron techron gas or just any ol gas?
    Thanks guys, you are all a huge help.
    Even Cmack :)
  2. May 5, 2010 at 8:40 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You are supposed to mix the fuel tank cleaner with regular gas, not fill the whole tank with the cleaner. A bottle like this one is good for one tank of gas.
    http://www.autobarn.net/ch67740t.html?site=google_base
  3. May 5, 2010 at 8:41 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I buy the big bottle, a little extra is not going to hurt your truck. I like the Chevron gas because it has Techron in it but I will fill up almost anywhere.
    If you have a problem with your injectors 3M makes a kit that you disconnect the fuel line and run it off the 3M bottle and it is reported to really clean up the injectors. Some of the shops and oil change places offer the 3M flush for a fee.
  4. May 5, 2010 at 8:49 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I use the larger size bottle every so often. Since owning my truck 3 years ago I've only used Chevron gas. The truck runs great on regular and when towing the boat I treat it to a fill-up of the higher octane.
  5. May 5, 2010 at 11:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I use the larger bottle with a full tank of gas at a fillup. I probably do this every oil change.....
  6. May 5, 2010 at 12:02 PM
    rmerchant3
    rmerchant3 Insert nonsense here
    Just use the small one like you said...when you get down between 10 and 15 gallons. Then run it till almost empty. Your just trying to reach a percentage of the fuel additive per gallons of gas. Why waste money ya know?
