Techron/ top tier gas/ valve deposits
Discussion in 'General Tacoma Talk' started by Koolbreeze7, May 18, 2025.
  1. May 18, 2025 at 8:38 AM
    Koolbreeze7
    Koolbreeze7 [OP] GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
  2. May 18, 2025 at 8:44 AM
    Bishop84
    Bishop84 Well-Known Member
    My problem is its so diluted it barely works.
    Actual EFI cleans make way more sense (if done correctly)
    When I was in school my buddy had an altima with a leaking EGR, the compression was 150-120-110-150, so the deposits were accumulating on the 2 middle valves. We did a hot injector purge and restored the compression, I remember it was 150-140-135-150 it was massive. We blocked off the EGR after that.
    Its basically raw acetone, so it would detonate underload, but at idle and reving no issues. We always do 1500-2500rpm hot hot hot at my work.
    Finding a place that does proper cleans? Hard to find. With D4S you need to connect the purge system to the port injectors and set the system to run on port. Some hook it up to the direct injection but it doesnt clean the deposits on the intake valves.
    Koolbreeze7[OP] and 3JOH22A like this.
  3. May 18, 2025 at 10:18 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've used Techron additive in my 07 since new. Does it work? Who the hell knows... just trying to get through the 12 cases my Dad left me lol.
    Have never heard the "taco tic" people speak of... any chance the Techron has something to do with that? :notsure:
