Techstream and TSS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by @BacktothefutureYoda, Mar 14, 2024.
  1. Mar 14, 2024 at 12:49 PM
    @BacktothefutureYoda [OP] Member
    2018 offroad to the max
    Engine: procharger | URD radiator Suspension: fox race dsc remote 2.5 shocks| baja uniball uppers | fox dsc 16” shocks | deaver stage 2 leaf springs Drivetrain: 4.88s | cvj axles | stop tech 4 piston calipers Body: lil B’s front bumper | outland rear bumper | wilco tiregate | kc roof rack Armor: cbi skids | marlin crawler frame brace | spindle gussets Lights: 2022 trd pro headlights | kc 50” pro6 8 bar |2x kc flex era 4 | 2x kc flex era Winch: warn 12s Accessories: built right full bedside molle panels | 2x rotopax | pro eagle bed mounted jack | vair compressor Audio: jvc 11” touchscreen head unit | 4x alpine 6x9 speakers | alpine 8” powered sub Misc: vls boost gauges | vls intercooler dual temp gauge |
    Hi all, I have a heavily modifed tacoma with an aftermarket grille. I jerry rigged tss sensor years ago and never had an issue. Out of the blue in perfect weather I get a tss and pcs malfunction. I have a copy of techstream, I was able to permanently disable the pcs and clear that warning, but havent figured out how to disable tss or clear that warning. I checked the ecu no2 fuse and seems as fuses are good. I was in a bit of dust leading up to the malfunction but wiped the sensor down. Does anyone know if you can disable tss with techstream? Do these sensors fail?
  2. Mar 14, 2024 at 1:00 PM
    51Beets
    51Beets Well-Known Member
    2020 TRD Offroad
    Too much to list
    I don’t believe you can disable the TSS at all. I was having issues with mine last year, couldn’t disable it and it damn near wouldn’t let me try my truck without randomly braking hard AF.
    I replaced it and had it recalibrated.
