Tekonsha P3 Electronic brake controller...Is it Good..??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Tacoma, Nov 19, 2010.
  1. Nov 19, 2010 at 9:27 AM
    Mr.Tacoma
    Mr.Tacoma [OP] Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    Any one using this on Tacoma..are they really good.?
    Thnks in advance :)
  2. Nov 19, 2010 at 9:36 AM
    airdough
    airdough Member
    Im using the P3 with my Jayco 19' trailer (4000lb dry weight) trailer. Works well for me. I have a Doublecab 4.0L Prerunner Tacoma. This is my first brake controller so I don't really have anything to compare it to, but its easy to set-up, and seems to work well.
  3. Nov 19, 2010 at 7:34 PM
    Mr.Tacoma
    toronto
    DoubleCab4x4
    Did you set it up by yourself....thanks for reply.;)
  4. Nov 19, 2010 at 7:43 PM
    Rodallg
    Rodallg Well-Known Member
    CA
    Hows the truck pull the trailer? Gas milage? Is there a harness for the controller already installed?
  5. Nov 19, 2010 at 7:44 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    If you have the factory towing package.
  6. Nov 21, 2010 at 3:31 PM
    airdough
    airdough Member
    I dont have the factory tow package, I installed a hitch, trans cooler, wiring and brake controller. Got all the stuff from etrailer and they have some pretty good videos that walk you through installation. I have a 4.0L Doublecab PreRunner TRD, and installed a 3" lift with 295 tires. When pulling the trailer, it did ok...struggled up hills. I live in San Diego and tow up the coast, and its pretty hilly. Anyways, I ended up regearing to 4.56 and it tows much better now.
    Oh, the tacoma without the towpackage did not have the harness, I had to wire it all in (tied into the brake line and power from the battery), but it was pretty simple.
