TELL ME WHERE I AM WRONG...I speak for many NEW GUYS to lifting
Discussion in 'Suspension' started by ChuckLee, Jul 11, 2011.
  1. Jul 11, 2011 at 6:30 PM
    ChuckLee
    ChuckLee [OP] Well-Known Member
    Richmond, VA
    06 SR5 4x4 DC
    I have read stickies, and days worth of reading and searching this forum. I am now ready to post questions. I am going to lift my 06 DC 4x4 SR5 WITHOUT UCA replacements (and will keep 2" or less of lift up front to hopefully ensure no problems with alignment)
    Now that I have clarified those things....suspension gurus please tell me where I am wrong and give any advice that I may need to hear (please refrain from replying "DO a search" or "Read the stickies" or any other comments. Instead, post the link to the sticky or thread you are talking about in an attempt to help. This thread should help others also when finished because as I am noticing many many people want a small lift without replacing expensive components (UCA's) and have honest questions. Please remember that to new guys to tacomas and lifting, there are SOOO MANY OPTIONS out there that it gets quite intimidating! Please keep this thread helpful, and not hurtful.
    That said, tell me where I'm wrong and give advice.
    1. 5100's up front set at 1.75" is ideal for the money (i'm not an off-roader, but I want a small lift and don't wanna trash my suspension or alignment).
    2. Front 5100's set at 1.75 preloads the shocks....meaning the lift is coming from the shock and not the spring. It is better to go with the 5100's set at 0" and Eibach springs to give softer, more natural highway drive. What springs will give me 2" lift with 5100's at 0??? I am not interested in spacers to lift the truck, as I have read all over that this isn't an ideal way to lift truck. Would OME 884 springs be best and 5100's set at 0?
    3. 5100's in rear with a toyTec 2" AAL will NOT work....???? If this is true, please discuss in more detail and provide best alternative for money. I want factory rake look, so I also want a 2" lift in rear, but obviously i still want to be able to have some down travel and 5100's don't allow this. Is the cheapest fix here using 5125's in rear with 2" AAL??? This will give more down travel from what I understand.
    3. AAL info: I definately want an AAL kit with anti-friction pads to prevent squeak noises, etc. 2" toytec AAl is good choice because it will settle over time. (no need to throw out 10 other options for AAL's if this works for sake of lessening confusion) With the toytec 2" AAL lift will I need to pry factory leaf brackets open in order to add the new leaf or will the 2" toytec slide right in place? (i don't know if I have TSB leaf set-up at this point, just bought truck, sorry. Tell me if that is something i MUST know and I will find out right away)
    Thank you everyone that has already contributed to this forum. Great place to be for sure. I look forward to continuing my learning at the TacomaWorld of Learning and Devlopment
  2. Jul 11, 2011 at 6:37 PM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    When ordering your AAL you have the option of getting the AAL with TSB or without. If you have 4 leaves, then your have the TSB. But if you have 3 you have the regular non TSB leaf pack
  3. Jul 11, 2011 at 6:43 PM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    Thank you Luck3. I am going outside now to check......:rolleyes::rolleyes::rolleyes::rolleyes:
    OK.....3 leaves.....no TSB, and I can see where the rubber stopper HAS in fact made contact with frame multiple times...interesting. Truck now has 83k so fix aint free.
    Thanks again for first comment!
  4. Jul 11, 2011 at 8:14 PM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    Great input Anthony! Thanks for clearing up the first error i made! The spring is preloaded, not the shock.
    I believe the 884 spring would work for my scenario, and with 5100's would give me a 2"lift.
    Would I be better off with 5125's in rear (99% pavement driving) with 2" AAL or 5100's with 2"AAL??? Do the 5125's present new problems (i.e. other adjustments like lengthening brake lines, etc)
  5. Jul 12, 2011 at 2:04 PM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    TTT anyone else want to chime in here? Feel free.
  6. Jul 12, 2011 at 2:17 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    is 5100's at 2.5" with the toytec 1/4" top plate spacer(for .5" lift) bad? I occassionally off road..and I want a full 3" lift
  7. Jul 12, 2011 at 2:29 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    You have been wrong about one thing. You have neglected to mention how much money you want to spend.
  8. Jul 12, 2011 at 5:47 PM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    I'm sorry. Parts under 750 bucks total. If i was an off-roader I'de get the UCA's and off road shocks but i just asthetics SAFELY.
  9. Jul 12, 2011 at 5:58 PM
    Treedawg37
    Treedawg37 Well-Known Member
    Barry
    Central, Alabama
    '11 Tacoma DC 4X4 SR5 SB,
    BHLM, tinted tails, weathertech mats & visors, sportsman"s camo seat covers, diff breather mod.
  10. Jul 12, 2011 at 6:04 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    You want a small lift. IMO, I think Eibachs/5100s set at zero and a 1 1/2 aal would suit you. YES, you can use the TSB aals on non TSB leafs.
    I'm suggesting this from experience. I had 5100s set at .85 with the Eibachs, 2" aal. (no tsb) and I had a noticeable rake. I'd imagine if you do ~2" of lift upfront and do a 2" aal, you'd have a crazy rake.
  11. Jul 12, 2011 at 6:07 PM
    dbronzo
    dbronzo Protected by Armor Tech Offroad
    Dennis
    Fayetteville, NC
    08 TRD Sport 4x4 w/ some Mods
    King Coilovers, LR UCA's, All Pro Sliders, ATO Full Skids, Pioneer AVH-P4300, 4.56 Gears, Front and Rear ARB Air Lockers, ATO Full Wrap High Clearance Bumper w/ Tire Carrier, ATO Hybrid Bumper, Smittybuilt XRC 8, Lightforce 240 Blitz, Rock Lights
    You can actually order longer 5100's from DSM. I had the ones that came with the TOYTEC lift and snapped one of the shock stems this weekend. On a side note I do wheel on a regular basis. I would contact DSM about the setup you are looking to run and they can probably give you the exact setup you are looking for at a great price.
  12. Jul 12, 2011 at 8:51 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Just fyi....With a non tsb leaf pack (3 leafs) you can use either AAL the 1.5" or the 2.0" depending on the height you're looking for. (Its the 2.0" AAL that won't work with the tsb 4 leaf pack) I'm running billys at 1.75 stock springs and a non tsb leaf pack with the 1.5" AAL and the rear sits alittle higher than the front. Perfect IMO
  13. Jul 13, 2011 at 5:11 AM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    Nice lookin lift there buddy! If i do the OME springs and 5100's at 0 i'll have right around 2" so if I go with the 2"AAL i think the rake should still look pretty stock, and will even probably settle abit and look more leveled over time than stock no?
  14. Jul 13, 2011 at 5:14 AM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    Do you mean after install your rake increased? If i lift both ends 2" won't the rake remain the same or close to it? I'm only thinking goin with the OME springs because it gives me just a little bigger lift without preloading. If I preload with eibachs or OME's i would probably need UCA's anyhow. I'm avoiding all that for now.
  15. Jul 13, 2011 at 6:06 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    The OME's are a taller coil than the Eibachs but a softer spring rate. The amount of lift you'll gain between the two would be very comparable, you'd end up most likely right at 2" from the OME and just under with the Eibach.
    The AAL might give you a little over the advertised lift and will settle some with time. That being said, you could end up with slightly more rake than stock but in theory, you shouldn't. A full 2" lift all around should maintain stock rake just 2" higher.
  16. Jul 13, 2011 at 6:10 AM
    Pugga
    Massachusetts
  17. Jul 13, 2011 at 6:30 AM
    tacobox
    Thanks man . That sounds like a good plan but if you're going with the 2" aal, you might want to consider the 885 springs. Search for pics of each and you'll see the difference.
    I'm about to replace my front coils with 885 (maybe 886) to help with the added weight of a plate bumper and a new rear leaf setup to help match the performance of the rear leafs to the performance of the front coil spring/strut setup. Still researching on the rear though.
  18. Jul 13, 2011 at 6:39 AM
    LEX
    Houston, Texas
    100 Series LC
    This
    To add, If you're only going to remain 2.5" or under, you won't need UCAs.
  19. Jul 13, 2011 at 8:00 AM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    All I have up front is an avid light bar...nothing too heavy. 885's will make a rougher ride right?
  20. Jul 13, 2011 at 8:50 AM
    Pugga
    Massachusetts
    Not necessarily, the 885's and 884's have the same spring rate, the difference is the 885's are 10 mm taller.
