Tell me why this idea sucks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by arthur106, Dec 16, 2024.
  1. Dec 16, 2024 at 9:44 PM
    arthur106
    arthur106 [OP] Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    The brakes in my truck really suck, super spongey, even after a brake job and a good bleed. Some of you have suggested it's likely air trapped in ABS system. I understand this is realistically something the dealer needs to do because it requires a special scan tool to get the ABS valves to purge the air. I really don't want to pay the dealer for this because I'm a cheapskate and it just rewards them for creating something we can't realistically repair ourselves.
    Why don't I put all four corners of the truck up on jacks tomorrow. I'll connect three of the brake lines to a bleeder bottle and leave the last one connected. I'll hop in the truck and get the wheel speed up to about 30 mph and then get on the brake just hard enough to gently stop the one wheel that still has brake line connected (the others should just free-wheel). I think this SHOULD set off ABS as it is seeing one wheel decelerate much more quickly than the others. This should force air out of the abs lines. I can do this 4 times, leaving each wheel connected during one of the runs.
    I'm a bit sloshed rn, so please, someone tell me why this is a bad idea?
  2. Dec 16, 2024 at 9:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Jojee117 and usmc2msu like this.
  3. Dec 16, 2024 at 9:51 PM
    whatstcp
    whatstcp currently drunk so don't listen to me
    Nah, too risky with vibrations that the jacks can fail/tip.
    Instead, drive down an empty lonely road and slam the brakes a few times to cycle the abs? Dirt road is even better as you can stand on the brakes a good bit. Just don't go fast or forget to secure anything not tied down, especially your tall can
    Jeffch and arthur106[OP] like this.
  4. Dec 16, 2024 at 9:59 PM
    arthur106
    Jacob
    Houston
    Yeah, I thought maybe the torque reaction from "slamming" on the brakes could maybe disrupt the balance on the stands.. I figured I'd go REALLY gentle to get the wheel stopped and then ramp up the pressure to get the fluid moving.
    The problem I'm having is that the brakes don't have enough clamping force to lock up wheels on dry pavement except for very sporadically and momentarily if I JOLT the brakes to disrupt balance. I don't feel like waiting till the next time it rains to get this taken care of. I realize it sounds a bit sketchy, but would simply getting the wheels spinning to 30 MPH really be a hazardous if all four corners are supported? Serious question, I wouldn't have thought that "vibrations" from balanced wheels would be substantial enough to worry about, but that's why I'm asking...
  5. Dec 16, 2024 at 10:08 PM
    MGMDesertTaco
  6. Dec 16, 2024 at 10:11 PM
    arthur106
    Jacob
    Houston
    Aight guys, should've saved this for Friday... I know..
    ...buuuttttt, will it work?
    Steves104x4 likes this.
  7. Dec 16, 2024 at 10:17 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    What’s the plan for when one jack stand fails and you drop a tire onto the ground, spin off the rest of the jacks and only have one wheel with braking power for a couple seconds before the fluid blasts out the three other disconnected lines?
    Duck_Hunter and JasonLee like this.
  8. Dec 16, 2024 at 10:26 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I’m not saying don’t do it, but if you do, record and post to YouTube. Link the video in this thread.
    (Please don’t do any of what I described)
    burlyb, JMcFly and WheelinDev like this.
  9. Dec 16, 2024 at 10:31 PM
    arthur106
    Jacob
    Houston
    Ok, so hear me out and think about this logically. Why would it fall off the stands? Serious question. The best answer I can think of is because slamming on a brake while a wheel is spinning creates a lot of torque.. for every action there is an equal and opposite reaction. I did some back of the envelope calcs and believe that this could be an issue with as little as 40mph/s^2 of deceleration which is totally doable considering the speed of the entire truck is no longer correlated to the rotation of the wheel. ....BUT why do the wheels/tires have to be on at all? If all four corners are on jack stands, I can just take the dang wheels off, now there's VERY LITTLE rotational inertia, negligible torque when I hit the brakes, and little to no vibration.
    I'm not trolling, I really think this could work but like many of you, I do see a possible unpleasant ending. What I'm specifically asking is HOW (by what mechanism) might I arrive at an unpleasant outcome? If I can mitigate it, I will. If I can't, I'll admit that this was a stupid drunken idea and y'all came make fun of my dumb ass.
    Edit: Free-wheeling wheels would need to have wheels bolted on to keep their momentum, also might get some weird undesired affects from differential if there's very little mass on one of the "free-wheels". But the wheel with the brake line connected would definitely need to be disconnected for safety.
    Clutch should be depressed with transmission in nuetral. I'f my udnerstanding of an open diff is correct, deceling one wheel while the driveshaft is powered and roatating at a constant speed will cause the other wheel to accelerate.
  10. Dec 16, 2024 at 11:46 PM
    JamesR
    JamesR Well-Known Member
    James
    Northeast PA
    2022 Tacoma Sport DCLB, Barcelona Red
    Why not just get a scan tool like the XtoolD7. I have that one and it has saved me $$ multiple times on my other vehicle enough to pay for itself. It’s under $400. It has plenty of special diagnostic functions. ABS bleed being one of them. I’ve used it to program new key fobs, reset and program TPMS sensors, put electronic e-brakes in service mode for installation of new rear brakes, run advanced diagnostics on my vehicles as well. It’s pretty handy once you learn how to use it.
    Steves104x4 and arthur106[OP] like this.
  11. Dec 16, 2024 at 11:56 PM
    arthur106
    Jacob
    Houston
    that would be ideal, but I read an old thread recently that suggested known reasonably priced scan tools on the market would not work for my 2010 base model.
  12. Dec 17, 2024 at 12:28 AM
    JamesR
    James
    Northeast PA
    Contact the folks at Xtool to be sure. Ive used mine on our 2018 Buick and my old 2009 Honda Civic. Not sure on the compatibility with your 2010 Taco though.
  13. Dec 17, 2024 at 2:47 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Why?
    Family tree photos
    KING ARTHUR
    Bubba Arthur
    Ma Arthur
    Uncle/dad Arthur
    It never ends well
    Lawfarin and Steves104x4 like this.
  14. Dec 17, 2024 at 3:20 AM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
  15. Dec 17, 2024 at 3:49 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Curtail the mid week heavy drinking and then you'll have plenty of dough to work on the most important safety system in your vehicle.
    Just a thought.
  16. Dec 17, 2024 at 3:53 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Or drink more to slow your reaction time to the point you don't need brakes.
  17. Dec 17, 2024 at 4:05 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    That’s the way I drive. I haven’t touched the brakes since 2010. My truck has 184,000; the brakes have 400 feet on them.
  18. Dec 17, 2024 at 5:44 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    Do it...itll be fine...:burnrubber:
  19. Dec 17, 2024 at 5:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Come on man. That's the easy way to access the spare trick.
    AnotherDude likes this.
  20. Dec 17, 2024 at 7:08 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    “WHY DID YOU TURN!!!???”
