Tell me y shouldn't i turbo
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hot Chillae, May 12, 2012.
  1. May 12, 2012 at 12:57 AM
    Hot Chillae
    Hot Chillae [OP] Active Member
    Garrett
    Springfield, MO
    16' Inferno Taco
    pending.
    Ok so ive got the 1st gen PreRunner, with 2.7 4Banger. everyone wants power without dropping a couple grand on an elaborate turbo kit, but why cant i just get a generic kit? say for instance this
    http://www.ebay.com/itm/Custom-Race...ruck_Parts_Accessories&vxp=mtr#ht_4969wt_1037
    i know it may require some hard work and custom fabrication to get it all to squeeze in there, but give me some good reasons. first of all im not sure if this turbo will mount up to a stock header. which if it did cool, if not im buying a performance one anyway and could have a custom adapter plate made right? i know the basics of how to set this up so don't suggest "searching" ive done that too. :p
    p.s. i realize id be running minimal boost and that the description is bogus on this ebay item. :)
  2. May 12, 2012 at 1:02 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Go for it! Boost > blown imo :crapstorm:
  3. May 12, 2012 at 1:12 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Go to customtacos.com right now.
    no one on here knows anything about turboing tacomas. but on CT they are everywhere.
    I can tell you now tho that that custom fab manifold and such is the hardest part. There is a pre made T4 turbo manifold for your motor tho i think.
    also..in terms of turbo stuff..you get what you pay for..
    my advice, if you turbo, do it RIGHT the first time or you'll be rebuilding a full motor. Get good quality parts.
    you will also need some fuels mods too or you'll be limited to like 2-psi outa a 45mm Inducer wheel turbo. You'll need injectors, fuel pump, wide band, and a piggy back tuning device to keep your motor in control. Also a boost controller and turbo timer.
    its not easy..why hardly anyone does it.
    ill be doing it tho some day here soon..
  4. May 12, 2012 at 2:03 AM
    Hot Chillae
    Garrett
    Springfield, MO
    16' Inferno Taco
    pending.
    Thanks for the advice on CT. i figured id need more fuel. but i only planned on doing 5-8psi. and the great thing about that kit is it comes with a timer and a boost controller :D but yea not sure where to get a moderately priced piggy back tuner. and i do need to do more research on the aftermarket fuel delivery options. i plan on doing a mid mounted turbo tho. seems easier than cramming all that shit into the engine bay
  5. May 12, 2012 at 7:59 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no room for a mid mount. Only options are rear mount and front mount.
    and rear mount will be easier. You'll have like lag but very small amount, only like 700rpm difference if you pick the right turbo with the correct setup.
    a front mount isn't as hard as you would think really.
  6. May 12, 2012 at 8:00 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    WUT
  7. May 12, 2012 at 8:06 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    yeah don't do the cheap chinese ebay junk. Collect the parts you need from reputable brands and do a custom build, otherwise don't even bother.
  8. May 12, 2012 at 8:07 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yep 100% agree with those guys.
    in other words..it'll cost you between 2-4k to turbo it the right way. hence a nother reason its more popular to SC
  9. May 12, 2012 at 8:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    a well matched turbo with the correct sized Incuder and A/R ratio will out do a SC any day. In other words a fairly smaller turbo..like a 40-45mm inducer maybe a 50-57mm...and like a .58 A/R
  10. May 12, 2012 at 8:46 AM
    Hot Chillae
    Garrett
    Springfield, MO
    16' Inferno Taco
    pending.
    I think you guys missed the point. i know its cheap that is the reason i would get it. why spend 4k dollars on brand name just to run 5psi? and i don't think it matters what brand it is because 5psi is 5psi no matter who pushes it... besides it the turbo cant run out of control IF i hook up the boost guage/timer correctly :) i know thats a big IF on my part.
  11. May 12, 2012 at 8:48 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    better turbos have better bearings and will be far more reliable, and will be more efficient.
    If all you want is 5psi then you could run a pretty small turbo and avoid the lag.
  12. May 12, 2012 at 11:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wrong. psi is relative to the turbo. 5 psi of of a turbo set up like X will be COMPLETELY different then 5 psi out of turbo Y. How the turbo is made, what features it has, and more all effect the overall efficiency of the turbo. Psi doesn't mean shit really.
    oh yea..and btw..cheap and forced air induction..NEVER works out.
    cheap parts are just gonna make your motor way more unreliable.
    this is true too.
    cheap turbos oil seals go bad fast too. Then you'll be dumping oil in your exhaust like a mofo. cheap waste gates can stick open rendering you turbo useless or out of control since the wastegate is what controls the turbo.
    OP..no offense..buy you have a TON of homework to do before you even start thinking of what parts to buy. Please do a lot(i mean A LOT) or reading. You do not seem like the kind of person that knows a lot about FAI and especially turbos.
    Do it right..or don't do it at all.
    you will just suffer having to rebuild a whole new motor if you do it wrong.
    In short, i do not think you are ready to turbo your truck in anyway shape or form.
    If you want a boosted motor..get a TRD SC. You can find em for 1k or a little more. Then go from there.
