tell the this isnt as bad as i think, 99, v6
Discussion in 'Technical Chat' started by Quadrcr161, Sep 19, 2009.
  1. Sep 19, 2009 at 5:12 PM
    Quadrcr161
    Quadrcr161 [OP] Active Member
    Scott
    Wetumpka Al
    99 Tacoma
    i just picked this truck up not too long ago, its a 99 SR5 V6 auto 4x4 with 220,000 miles. the truck dosent smoke, seems to run pretty well, dosent use any oil that i know of and gets the gas milage i think it should. the previous owner was an idiot, said he changed the oil regular but the K&N air filter was filthy. the truck was a lot dirtier then i thought and stained the hoses and such, even after 2 hours with the pressurewasher. Well the passenger side valve cover was leaking a little oil, just enough to get a smell when you stopped and it needed new belts. Ive replaced the belts and this evening i pulled the valve cover to change gaskets and this is what i found. im thinking the motor needs to be flushed out, like seafoamed with new oil and filter, or do i need to put it back togeather and sell it to try and salvage any money back out of it. the frame dosent have any rust issues and looks to be in ok shape. anyway back to the pics.
  2. Sep 19, 2009 at 7:01 PM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    For 220,000 miles, this looks pretty clean. With this mileage, I would certainly expect SOME leakage, smoking, or some sort of wear indicators. I would say keep it and enjoy making it sing again. She seems to have many songs left in her.
    A Toyota with that many miles is still not "wore out". This is why we maintain our Toyotas well. So they get to 220,000 miles and still run well. I would assume there is some sludge in the pan and settling areas, but that can be dealt with.
    I say be happy and now you have a project. A strong truck with much truck left.
  3. Sep 19, 2009 at 8:01 PM
    Quadrcr161
    Scott
    Wetumpka Al
    99 Tacoma
    the milage dosent scare me,one reason i went with a toyota to replace my honda. its the grit and the burnt looking grit in the top of the valve cover along with the texture/color of the top end. wasnt looking for a project, i have plenty of those was just wanting a realiable daily.
    more pics
  4. Sep 19, 2009 at 8:14 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    yea for 220K i wouldnt worry about it. Just replace the valve gaskett and drive it with regular maintence. If your going to be using seafoam, just be careful with it since that gunk may be plugging small leaks here and there. I'd say run a can in your gas tank and call it a day.
  5. Sep 20, 2009 at 5:43 AM
    Warren Thompson
    Warren
    Elko, Nevada
    Your cam surfaces look clean and polished. Not scored or pitted. This engine has had good maintenance. I agree with wildjersey on this.
    Enjoy your find. A well maintained toyota will continue to deliver many more miles.
  6. Sep 20, 2009 at 6:48 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    drive it. you cant expect a spotless motor for 220k miles. worse case, get a replacement motor if that one takes a shit.did you get the truck for a "good deal"?
  7. Sep 20, 2009 at 7:29 AM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Theres nothing wrong with that top end at all. Its not even sludged up. The texture you see on the cams is just the area where it wasn't machined.
  8. Sep 20, 2009 at 7:31 AM
    Quadrcr161
    Scott
    Wetumpka Al
    99 Tacoma
    ok deal, seen some older go a little higher seen some newer in worse condition. it just worried me with the grit and such in the valleys, i can go pull the valve cover off my 90 crx and it is spotless. ill do a good oil change and make sure to keep a good filter on it. Thanks for the input.
  9. Sep 20, 2009 at 7:57 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Well said.
    My only concern would be when was the timing belt last changed?
  10. Sep 20, 2009 at 8:11 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    these guys are smart, so I'm gona go with them and say drive it, i will add, that you should run 1/3 can of seafoam through the brake booster 1/3 with the motor oil an the last 1/3 in the fuel tank, drive it for 60 or so miles and then change a few things. as it's a new to you truck, after doing the seafoam, i'd replace the fuel filter, do an oil change and try synthetic, i dont think you'll have any leaking problems. hopefully you got a new air filter, if not do that too. and lastly clean your throttle body
    http://www.tacomaworld.com/forum/technical-chat/50153-how-cleaning-throttle-body.html
    then have some fun with it! thats a very nice looking truck.
  11. Sep 20, 2009 at 8:25 AM
    Quadrcr161
    Scott
    Wetumpka Al
    99 Tacoma
    i noticed the TB was a little dirty, ill prob try to clean everything while im into it.
  12. Sep 20, 2009 at 10:23 AM
    dwzild
    dwzild Well-Known Member
    Metairie, LA
    2010 MGM 4x4 Sport DC LB
    Hoo-rah! Sticker, Front Bed-bolt D-rings, Bed Mat, Weathertech Floor Mats, Sirius, TACOMAWORLD Sticker, Bak-Flip F1
    Agreed. That's a normal looking DOHC engine with a couple of miles on it. I've seen import heads turn that "rusty" color at about 75k that have been perfectly maintained. 220k miles, you're bound to have a couple of leaks. Slap some new gaskets on and you should be good to go for another 100k, judging only by the looks of your top end.
  13. Sep 20, 2009 at 11:43 AM
    Quadrcr161
    Scott
    Wetumpka Al
    99 Tacoma
    well, i guess no matter how much you try to maintain if the intake hose is cracked its not going to help. can anyone recommend a good intake?
  14. Sep 20, 2009 at 11:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    See if you can find someone seelling their OEM intake, then do a deck plate mod. :)
  15. Sep 20, 2009 at 4:42 PM
    Quadrcr161
    Scott
    Wetumpka Al
    99 Tacoma
    got the valve cover back on, patched up the intake tube and cleaned the MAF and the TB a little. Still has a burnt oil oder, could be from let over cooking off, i cleaned everything pretty well while it was apart, and its idling a little high, could be because of the cleaning and/or any air leaks, but i pulled the ecu fuses and going to restart it here shortly to see if that will help reset it.
